Activity Forums Adobe Premiere Pro Premiere Pro Performance Question
  • Premiere Pro Performance Question
    Posted by Tom Sven on September 2, 2006 at 6:36 pm
    Hopefully this isn’t a common question but if it is please bear with me.
    In the past I have been working with the older version of premiere, after FX, etc on a 3.2 p4 with 2 gigs of memory. I have recently upgrade both my system and to the new production studio pro. I now have a Boxx 7400 with dual dual-core Opteron 280 system with 4 gigs of memory.
    I have been testing projects in Premiere, , Encore, After Effects, and Audition I have been noticing that I am not even coming close to maxing out my processors. In all three programs they all average about 20-50% use under rendering, transcoding, and processor intensive tasks. I even created a benchmark test by timing one project in Premiere on the old computer and then on the new and it only had 10% increase in rendering speed with all the extra processing power. (I installed the new production studio on the old machine to make sure the test was accurate)
    I am basically trying to figure out what the bottleneck is. Could it be that the new production studio doesn’t multithread well? Are there some settings I should be adjusting? What is everyone else seeing when they render intensive tasks? I feel like I should be seeing better performance gains out of this new system.
    Any help would be greatly appreciated.
    Tom
    Steven Pribilinskiy replied 19 years, 12 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mike Velte
    September 3, 2006 at 11:50 am
    Yours is a typical experience…folks with dual Xeons have the same issue. Upside is that you can multi-task while rendering.
  • Tom Sven
    September 3, 2006 at 4:40 pm
    Has anyone found a solution to the problem?
  • Andre Gagnon
    September 3, 2006 at 7:47 pm
    [Tom Sven] ” I feel like I should be seeing better performance gains out of this new system.”
    It may very well be that your performance in limited by the hard disk Read/Write operations required by Premiere Pro.
    In order to insure best performance from your drives you should:
    1) Combine the operation of two SATA similar drives in a RAID 0 configuration and use the tanden as the A/V drive. This usually more than doubles the Read/Write speed.
    2) Make sure that your system, A/V and export drive (if any) are not more than 80% full.
    3) Often defrag these drives. Perfectdisk 7.0 is recommended for its defrag speed and it’s analysis tool that clearly identifies the type of defrag needed when applicable.
    https://www.raxco.com/products/perfectdisk2k/
  • Tom Sven
    September 5, 2006 at 3:15 pm
    Thanks for the tips, Do you know of any utilities available for watching the amount disc usage while doing task?
  • Andre Gagnon
    September 5, 2006 at 7:14 pm
    [Tom Sven] “Do you know of any utilities available for watching the amount disc usage while doing task?”
    No, I am not aware that such utility exists.
    If you are interested in a utility that measures the Write and Read throughput of hard disks, give your e-mail address in a reply and I will e-mail it to you.
  • Tom Sven
    September 5, 2006 at 9:41 pm
    Ok great thanks.
    Boss428stang@hotmail.com
  • Steven Pribilinskiy
    September 7, 2006 at 2:29 am
    You can simply measure this in Windows Task Manager (invoked by Ctrl+Alt+Del). Select View > Select Columns in it. Select I/O Writes/Reads in the Dialog. Let me know if this worked for you.
