Activity Forums Adobe Premiere Pro Premiere Pro or Canopus DVStorm problem w/color correction?
  • Premiere Pro or Canopus DVStorm problem w/color correction?
    Posted by Jeff Nelson on June 16, 2006 at 5:27 am
    I’m using the canopus video filter to do some heavy color correction and the WEIRDEST things are happening. The shot alone is fine. I add the video filter and adjust the picture, and halfway through the shot there’s a skip where it skips forward a frame, and then the last frame in the shot is duplicated, like a momentary freeze frame.
    I noticed that after I put the effect on, when I render the shot it renders it in two pieces — even though it’s one continuous (short) shot! And where the break is is where it messes up.
    Anyone know how this could be happening? And what to do about it?
    Jeff Nelson replied 20 years, 3 months ago 2 Members · 2 Replies
  • Vince Becquiot
    June 18, 2006 at 5:13 am
    What format are you editing in ?
    The only time I have seen this happening was with Mpeg2.
    Vince
  • Jeff Nelson
    June 18, 2006 at 2:53 pm
    I’m editing usign Premiere Pro 1.5 and have a DVStorm card which I used to capture the footage to canopus avi files. What’s happening is that when I use the canopus color correction filter, when it renders a shot, it doesn’t render it as one shot, but breaks it into two shots, and where it’s broken the shot on render, it will duplicate one frame. I’m going through and re-rendering the shots, and stopping it before it renders the second part, and then starting it again, and this time it renders it correctly. But I have to render each shot in two steps or else I get this problem. Extremely weird!
