Activity Forums Adobe Premiere Pro Premiere Pro on a Mac
  • Premiere Pro on a Mac
    Posted by Jerry Dubinsky on October 5, 2008 at 3:14 pm
    I have migrated from Velocity to Final Cut Pro. I did have Premiere Pro on a PC but had the department shut down after 24 years. A lot of jobs I see now are either FCP or Premiere. I have an Intel Mac at home. If I want to get my chops back up on Premiere what package do I get and do I run it on the Mac side with FCP? ..or PC side of the MAC.
    Jerry
    Nigel Parkes-davies replied 17 years, 10 months ago 3 Members · 2 Replies
  • James Goodman
    October 6, 2008 at 3:15 am
    Jerry
    I moved to a MacPro tower this summer and for a nominal fee Adobe sent me the Mac version of the Master Suite (to replace my PC version) which includes Premiere CS3 and it installed fine on the Mac Leopard side. I use Sony EX1 footage and it edits it fine.
    The only issue I have had is that I also have a Matrox MXO/Apple Cinema combo for accurate colour display and it will not play EX1 footage back unless I disable the playback window in Premiere but FCP also has problems with EX1 footage.
    James
  • Nigel Parkes-davies
    October 7, 2008 at 11:40 pm
    I would recommend holding fire for a few more weeks and waiting for the release of Adobe CS4, as this will be the second iteration of the current Mac compatible Premier Pro and is reported to be a much more integrated solution. However, CS3 is no slouch and made a welcome return for Premier on the Mac.
    Whatever route you choose I would advise running the native Mac version – even Adobe commented on how well Premier runs on a Mac in comparison to the PC. Although I myself am a PC user, I would refit our PC gear with Mac hardware like a shot if I could warrant the outlay – far fewer “unknowns” in hardware conflicts and a much more efficient OS, in my opinion.
    Hope you have a pleasant return to Premier.
    Nigel Parkes-Davies
    Ephergie Studios
