Activity Forums Adobe Premiere Pro Premiere Pro on 64-bit WinXP?
  • Premiere Pro on 64-bit WinXP?
    Posted by Jack Kelly on April 27, 2005 at 9:07 am
    So, Microsoft have released WinXP 64-bit (aka win64). Does anyone know if Premiere Pro 1.5.1 will run happily on Win64? How does the performance of PPro on Win64 compare to AE on Win32?
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Brian Deviteri replied 21 years, 4 months ago 2 Members · 3 Replies
  • Brian Deviteri
    April 27, 2005 at 1:12 pm
    I just posted this message in another topic:
    This is being discussed on the Adobe forum as well…
    Someone on there is running an AMD 64-bit processor at 32-bits and it works fine. Right now, I doubt that PPro supports 64-bit processors in 64-bit mode. I’ve heard that even Windows XP Professional cannot handle 64-bit and that there is a copy you can get “somewhere” that probably isn’t 100% legal that can do 64-bit, but even then, unless the software application can do 64-bit, it will not work. I’ve also read reports of even MS Word not functioning on a 64-bit running system, so this is a major issue. I would wait until the end of this year or sometime next year when the “Longhorn” beta versions are released and tested before going with a 64-bit and running it in full 64-bit mode.
  • Jack Kelly
    April 27, 2005 at 1:22 pm
    Hi Brian,
    Thanks a lot for your reply. Please could you point me in the direction of the topic on the Adobe forums?
    Yes, I presently run Windows XP (32-bit) on my Athlon64 processor and that works fine. Microsoft released the WinXP 64-bit on Monday, so it’s officially ‘out in the wild’. Apparently it will run 32-bit applications in a wrapper.
    Here’s some more details:
    https://www.microsoft.com/windowsxp/64bit/upgrade/default.mspx
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
  • Brian Deviteri
    April 27, 2005 at 1:32 pm
