Activity Forums Adobe Premiere Pro Premiere Pro not opening
  • Premiere Pro not opening
    Posted by Thomas Steel on January 27, 2012 at 9:24 am
    So I decided to try and open premiere pro after a while of not using it and it wont open.
    Its showing in my task manager, and After Effects loads fine.
    But i have just left it there for over 10 mins now with nothing opening
    Any ideas anyone?
    Thanks in advance
    Tim Tyler replied 14 years, 7 months ago 3 Members · 4 Replies
  • Tim Tyler
    January 28, 2012 at 11:55 am
    Does it show up on the task bar?
    Tim
  • Kevin Ryan
    January 28, 2012 at 12:51 pm
    Check in task manager to see if it already running. If so, close it outin task manager, then open from desktop.
    Kevin Ryan
    Editor/Graphics
    The Government Channel
    City of Charlotte
    Charlotte, NC
  • Thomas Steel
    January 28, 2012 at 9:09 pm
    I already have tested the task manager option and yes it is appering in the task mananger,
    And I opened it from the root folder not using any shortcuts or links.
    Im running windows 7 and I also have the link pinned to the task bar, and Its not doing its usual thing where it says the program is running by putting the button thing on (If that makes sence)
    I may re-install the program later today when I have some free time, but if anyone knows of any fixes I would be greatful.
    Thanks In Advance
    Thomas
  • Tim Tyler
    January 28, 2012 at 9:17 pm
    I meant, when the program is running, even though you cannot see it on the screen, does it have an running item on the task bar.
    If you have recently adjusted your display properties or monitor layout then it’s possible the app is displayed on a x/y monitor point you can no longer see.
    If that’s the case, right click on the desktop, select Screen Resolution, and then arrange the monitors differently while Premiere is running. It might just be hidden from your view.
    Tim
