Activity › Forums › Adobe Premiere Pro › Premiere Pro not loading
  • Premiere Pro not loading
    Posted by X(infinity) Media on March 29, 2007 at 2:38 pm
    I am having problems loading my latest project into Premiere Pro.
    The progress goes all the way to near the end and then just hangs there. I have tried loading the auto saves but they don’t work either. I have deleted the layout and style (after reading another post) and that didn’t help. I have tried importing the project into a new project and it still hangs.
    After Effects 6.5 loads the project with no problems at all.
    This problem happens on both my desktop and laptop. I have scanned the files for viruses but none.
    I don’t understand why After Effects will load the project but the native application, Premiere Pro, will not.
    I have been editing this for a couple of weeks and really don’t want to start from scratch!
    X(infinity) Media replied 19 years, 6 months ago 2 Members · 2 Replies
  • Vince Becquiot
    March 29, 2007 at 6:44 pm
    Have you tried importing it inside a new project? I remember other posts about this subject, and the only possible problem that I can think of here would have to do with one of the clips inside your project.
    I would move all the clips linked to that project WITHOUT THE PROJECT FILE to a new location; then, separate video clips in different folders; that will force Premiere to load them one by one. I know, it might be time consuming, but if it hangs on a particular clip, you know it’s the problem. Then you can try importing the clip to after effects and export it again to say, uncompressed.
    Premiere is a lot more picky about small errors in a clip (call it corrupted clip) than AE.
    Vince
  • X(infinity) Media
    March 30, 2007 at 3:24 pm
    Thanks.
    Moved the footage to a different folder and linked it to the files as and when needed.
    Found the one that was causing problems. Thankfully, it wasn’t footage that I had used.
    Cheers for the help.
