Activity Forums Adobe Premiere Pro Premiere Pro not encoding transitions!
  • Premiere Pro not encoding transitions!
    Posted by Scarlet Blacklove on April 24, 2009 at 10:00 am
    Help!
    I have a project for tomorrow that I am trying to encode but PPro will not encode the transitions. Instead of cross disolves and dips it switches straight to the next clip as if I had not applied a transition!
    Is there somethign I have to do before encoding? some equivalent to flattening layers in photoshop?
    Please help me, im screwed if I don’t get this encoded right.
    Also, does anyone know why a 5 min video always encodes to over a gig? wtf am i doing wrong with all this encoding?
    Nick Hill replied 17 years, 5 months ago 2 Members · 1 Reply
  • Nick Hill
    April 24, 2009 at 4:40 pm
    What settings are you using? There’s no reason why 5 mins should be over a gig if it’s compressed. If you’re in CS4 check the settings before you send to media encoder (you can also change them once you’re there) in particular the bit rate. A rough rule of thumb (at 25fps anyway) is width * height / 90 to give you a decent quality file – this is a subjective thing but seems to work. eg for a 720 x 576 project you get 720 * 576 / 90 = 4600 kbps. For the first part of your question – how are you applying transitions? I haven’t had that happen before but it can be temperamental… if you’re applying a cross dissolve effect for example have you tried setting opacity keyframes instead to fade from one track to the other?
    Cheers
    Nick
