Activity Forums Adobe Premiere Pro Premiere Pro: Nonsmooth Dissolve Transitions, Why is That?
  • Premiere Pro: Nonsmooth Dissolve Transitions, Why is That?
    Posted by David Laurent on June 14, 2015 at 11:22 am
    On Premiere Pro, when I put two different unconnected clips together and add a dissolve transition in between for smoothness, parts of the following & previous scenes that were cut out appear in the fade.
    Why is that? Could this be fixed?
    Shane Ross replied 11 years, 3 months ago 3 Members · 2 Replies
  • Pat Horridge
    June 15, 2015 at 8:06 am
    Are the clips from a longer piece of material?
    Sounds like your clips arent seperate.
    The disolve needs additional frames after the end and additional frames before the start.
    To fix trim the end of the first clip back half the disolve duration. Then trim the start of the second clip the same amount.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Shane Ross
    June 15, 2015 at 8:57 am
    To try to add to that explaination…you need handles. Meaning, if you do a 30 frame dissolve, you need 30 frames AFTER your last frame in order to make this smooth. If after 15 frames the image changes to the next shot, then that will show up in the transition.
    If you want a 30 frame dissolve, you need to go to the last frame, and then back up 30 frames, THEN mark it as OUT.
    Shane
    Little Frog Post
