Activity Forums Adobe Premiere Pro Premiere Pro noise reduction plug-in
  • Premiere Pro noise reduction plug-in
    Posted by Mike Nagel on January 9, 2008 at 3:34 pm
    I’m looking for a noise reduction plug-in for Premiere Pro CS3.
    The Adobe website plug-in section listed ‘Neat Video’ as a Noise reduction plug-in, which I’ve tested and is really good.
    Is there anything better out there ?
    What is ‘the industry standard’ ?
    Thanx for your help in advance !
    Mike
    Jim Arcon replied 18 years, 8 months ago 3 Members · 2 Replies
  • Vince Becquiot
    January 9, 2008 at 6:11 pm
    I guess I should start with “The industry standard” is to start with no noise. There are many more options available to After Effects than Premiere, for the simple fact that noise reduction is not usually the job of an editor. If you own AE, that’s what I would use. In combination with the filter you found, try slightly blurring the blue channel. Sometimes that’s the simplest fix.
    Vince
  • Jim Arcon
    January 13, 2008 at 1:09 pm
    There are some plug-ins that reduce video noise. They are often part of large sets of plugins and have a cost to match. I do any noise reduction in AE so my knowledge for PPro is a bit dated.
    There was a plugin called Vixen that included noise reduction. I think that Video Finesse was available in a version for Premiere, as was ViviClip. Grain Surgery was made in versions for AE, PhotoShop, and for Premiere. Boris Continuum (really meant for AE) also loads into Premiere – or at least it did when I used it some time ago.
    The AE noise reduction plug worked within Premiere, but you had to copy it from your AE folder into the PPro folder.
