Activity › Forums › Adobe Premiere Pro › Premiere pro menu templates do not show up
  • Premiere pro menu templates do not show up
    Posted by Nicholson Emilien on August 29, 2006 at 5:17 am
    I cannot figure out why when I try to change menu template I get only the first one Corporate/ ” Numbers”. I check the folders for templates are full of templates ( wedding etc)but they failed to appear in the box> please help
    Netvision
    Nicholson Emilien replied 20 years ago 2 Members · 6 Replies
  • Mike Velte
    August 29, 2006 at 11:57 am
    The DVD templates should be in;
    C:\Adobe\Adobe Premiere Pro 2.0\DVD Templates\en_US
    Half of them are PAL duplicates.
  • Nicholson Emilien
    August 29, 2006 at 6:00 pm
    It is like this on my machine: F:\Program Files\Adobe\Adobe Premiere Pro 2.0\DVD Templates\en_US\Corporate\Numbers
    F:\Program Files\Adobe\Adobe Premiere Pro 2.0\DVD Templates\en_US\Education\elephant
    F:\Program Files\Adobe\Adobe Premiere Pro 2.0\DVD Templates\en_US\General
    So it should work
  • Mike Velte
    August 29, 2006 at 7:53 pm
    Yes, but you dont have many folders of templates. The demo version does not include but one or two.
  • Nicholson Emilien
    August 30, 2006 at 4:48 am
    I understand but if I add good templates into the correct folder, should it show up or there is another way of adding new templates.
    Netvision
  • Mike Velte
    August 30, 2006 at 11:40 am
    I have done it and it works fine, even differnt folder names.
  • Nicholson Emilien
    September 4, 2006 at 7:16 am
    Thank you. I have found out the problem: I had to rename my files to say PAL_Weddding_mm for main menu and PAL_Weddding_sm for submenu.Then templates appear in change DVD templates drop down. I still got one problem. even the submenu icon appears in the drop down list.It dissapears when selected, only the main menu appears. So I cannot edit the buttons in the submenu for scenes.This is possible only for the first template i.e. Corporate/Numbers.I dont know what I miss.
    Netvision
