Activity › Forums › Adobe Premiere Pro › Premiere Pro Lag on FAST Computer ???
  • Premiere Pro Lag on FAST Computer ???
    Posted by Brian Rapaport on March 19, 2013 at 6:43 pm
    Hello, I recently purchased CS6 The Creative Suite which comes with Premiere Pro, initially I would have bought final cut Studio but because I already had Premiere I decided to not. ( I did in fact by Final Cut X but do not really like the way it operates sometimes compared to Studio)
    Anyways moving on. Each time I use Premiere I usually am editing a project that contains no more than 10-12 GB of HD 1080p Video. Now this may in fact be a rhetorical question, but I am wondering why Premiere lags and freezes every so often? Is this just because of the amount of memory being used?
    This usually occurs when Im scrubbing through the timeline. The Source Monitor will freeze on whatever clip the playhead was last on, even if I move the playhead. Next the Effects controls will freeze and so on. Typically the Program still allows me to click around, but doesn’t show any response. This usually only happens in waves, so to speak, and if I wait long enough the program seems to catch back up with it’s self.
    Can anybody better explain , or possibly provide a solution to this problem?
    I’m Running:
    A Mac Pro Version 10.8.2
    2 x 2.4 GHz 6-Core Intel Xeon Processing Speed
    64GB 1333 MHz DDR3 Memory
    ATI Radeon HD 5770 1024 MB Graphics
    and
    3, 3 TB internal SATA Disks
    500GB Flash Storage
    + 1, 500GB external drive & 1TB external Drive.
    I typically run everything off the External Drives.
    Thank You!
    Igazen Angel replied 9 years ago 9 Members · 11 Replies
  • 11 Replies
  • Alex Gerulaitis
    March 19, 2013 at 7:39 pm
    The first thing to do (usually) is to check what’s going on with the system when that lagging starts happening: disk or CPU activity, large memory footprint, and what’s causing it, which processes. Possibly Premiere Pro starts something in the background, or there is some other system process that slows down the system or causing issues.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Kevin Monahan
    March 19, 2013 at 7:48 pm
    [Brian Rapaport] “I am wondering why Premiere lags and freezes every so often? Is this just because of the amount of memory being used?”
    There could be many reasons why this is happening, unfortunately.
    How much RAM are you allocating to Premiere Pro? Check Preferences > Memory.
    Has the RAM been tested and is it good? Run the Apple Hardware Test.
    In Project > Project Settings > General, are you running the Mercury Playback Engine in Software Only mode or Hardware mode?
    [Brian Rapaport] “I typically run everything off the External Drives. “
    Are you running Premiere Pro off the boot disk?
    On which drive is the Media Cache and Media Cache database set in Media preferences?
    What is the connectivity with the external drives? eSATA? Firewire 800?
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Brian Rapaport
    March 19, 2013 at 8:17 pm
    Thanks guys!
    Kevin Monahan So I checked it out and right now, Premiere has 58GB of RAM available, 58 out of 64GB. As for the PlayBack Engine, the Renderer option is grayed out. However it does say Mercury Playback Engine Software Only, I just can’t click it– How do I change this? Other settings on it are Display Format: Timecode, Audio:Audio Samples, Capture:HDV– if that helps. How do I run the Hardware test?
    Nope, I am running it off of my Lacie 500GB External connected with USB 3.0.
    Oh well could this be it? The Media Cache Database is located on the Boot Disk— /Users/brian/Library/Preferences/Adobe/Common/
    Media Cache Files are located the same.
    In Media Settings I also have clicked:
    – Write XMP ID to files on Import
    – Enable Clip and XMP Metadata Linking
    – Automatically Refresh Growing Files every 60 seconds.
  • Kevin Monahan
    March 19, 2013 at 8:51 pm
    You should run Premiere Pro from the boot drive, not an external one. That’s the first thing to test.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Angelo Lorenzo
    March 19, 2013 at 9:02 pm
    Along with moving Premiere Pro onto an internal drive (or even eSATA, the USB protocols really just aren’t as responsive as you would think), you may want to check power saving settings. You may find that external drives are set to go to sleep. Try adjusting this setting under Preferences > Energy Saver. If this seems to be the issue I would see if there is a different program to control this setting with; Windows lets you set an idle time rather than just yes or no.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Dave Brandt
    March 19, 2013 at 11:44 pm
    How are you connecting that LaCie 500gb USB 3 to your Mac? There is no native usb3 on that Mac so it will default to USB 2 which is a bit slow for your needs.
    http://www.SolidMedia.ie
    Macbook Pro 17″ i7 2.2 8GB
    PC i7 32GB Self Build
    FCP 7 FCPX Adobe CS6 Vegas 12 Nuendo 4
  • Desmond Hew
    April 16, 2013 at 9:35 am
    Hi Kevin, got 3 questions about Premiere CS5.5:
    a) Which drive is recommended for the Media Cache and Media Cache [under the Media preferences]? Should it only be the Boot Disk? What about an external drive or will that slow things down?
    b) I’m also thinking of ‘cleaning’ the media cache [by clicking CLEAN of course] to free some disk space… But I’m worried it’ll make Premiere having to conform or ‘index’ all my 5000+ video files all over again when I re-open the project… Is this a bad idea or will it be fine?
    c) Can Premiere CS 5.5 [or CS6] detect/work with 32gb of RAM or even 64gb?
  • Sibel Zivy
    February 19, 2015 at 12:58 pm
    Hello I’m Running PremPro CC and I’m facing the same issues here.
    The only settings I’ve fiddled with are the playback engine which is set to hardware, I managed to do so from a thread by videoone, and the second is that I’ve moved my scratch out and back into my boot SSD.
    Re-cap( Lag when previewing video on source monitor)
    Specs- CPU: 6-core/12-thread i74930k. Clocked @ 4.15-Ghz.
    RAM: 8-Gbs 1600-Mhz.
    GPU: GTX 760 2-Gb version.@base of 980Mhz. Boosts to 1028Mhz when rendering.Max at 1033Mhz.
    1x SSD(128Gb) on which cc is installed.
    3x HDD of only one is 2TB runing @7200 which has all my video files and scratch files.
    Allocation ram is 6.5 Gb which is the max I can allow.
    I also preview at 1/4 quality( my videos usually range form 40mins@15~20 gigs upto 120mins@35~40gigs @1080p).
    With the given I shouldn’t be facing these issues, So what can I do to mend this and how can can I optimize my system to fully utilize CC’s demands.
    Please aide and Thank you!
  • Nils Welter
    February 24, 2015 at 10:14 pm
    Brian,
    Also your gpu could cause the problems. It’s an old and weak gpu. My experience with this gpu is to better disable gpu acceleration because the cpu can do it faster.
    We put newer nvidia cards in all of our macs.
    Nils Welter
    Adobe Certified Instructor – Premiere Pro
    CBC Cologne Broadcasting Center
    Cologne, Germany
  • Brian Rapaport
    February 24, 2015 at 11:34 pm
    Nils,
    Thanks for the tip. I am definitely going to look into possible upgrade solutions. Since I posted this the problem seems to have lessened a bit. I work with a lot of time lapse material, usually all in the native 5K shot on my 5D, then down scaled in premiere to fit the window. I’m going to look into Nvidia!
    Brian
    Designer & Photographer
    https://www.brianrapaport.com
    Creative Director
    Pixel Eyes Production House
    https://www.pixeleyes.co
