Activity › Forums › Adobe Premiere Pro › Premiere Pro is so hard to work on my MacBook!
  • Shane Ross
    January 9, 2018 at 1:02 am
    Convert the footage you are working with to ProRes or other more friendly editing codec (DNxHD). H.264 is a tough beast to edit native, and 1080p60 H.264…that takes a LOT of system resources to decode on the fly, more than a MacBook Pro has to offer. So convert the footage to ProRes or DNxHD and edit that. You’ll notice a difference.
    Shane
    Little Frog Post
  • Cihan Kurt
    January 9, 2018 at 12:28 pm
    First of all thank you for your comment. I did what you said and changed the format of the video. My CPU usage has been reduced from 300% to 200%. But this time my RAM usage has increased almost 3 times. Unfortunately I keep alive Frame drop.
    New format converted:
    https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-10090309-1390964/Ekran+Resmi+2018-01-09+15.13.33.png
    H264 format Ram used:
    https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-10090309-1390965/900-626/Ekran+Resmi+2018-01-09+15.01.10.png
    New Format Ram Used: (effect closed, resolution 1/4)
    https://forums.adobe.com/servlet/JiveServlet/downloadImage/2-10090309-1390966/900-626/Ekran+Resmi+2018-01-09+15.05.16.png
  • Cihan Kurt
    January 9, 2018 at 4:56 pm
    Yes I did not use any applications. iPhone’s own camera application. Would not it matter if I use filmic pro?
  • Cihan Kurt
    January 9, 2018 at 5:44 pm
    Well ☺ Yes, I know that filmic pro is really good. I just tried it in front of you, but the same problems persist. I need very serious help in this regard. I can not understand. Not even a 4k video. only 1080p! But I can not edit the edit frame droplard. I did 1080p 60FPS video recording with Filmic Pro. Then I threw him into the computer. What am I supposed to do in this state of affliction?
  • Jon Doughtie
    January 9, 2018 at 6:00 pm
    And the video clips are kept where?
    If your video is living on the same hard disk as your OS and apps, that is a recipe for unhappiness.
    I notice there appears to be nothing in your list of specs about hard disks or storage.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Cihan Kurt
    January 9, 2018 at 6:10 pm
    The application files are on the MacBook’s own disk. The media files are on an external hard disk. Is there anything else you can offer besides that?
  • Shane Ross
    January 9, 2018 at 6:29 pm
    [Cihan Kurt] ” The media files are on an external hard disk. Is there anything else you can offer besides that?”
    Yes. How is the hard drive connected? What kind of hard drive? Meaning is it a single, small USB 3 drive? It might be too slow for media. Is it a higher end drive that’s faster and meant for video editing? Is it a single drive, or a RAID drive? 1080p60 does require higher end solutions, as it is a high data rate format
    Shane
    Little Frog Post
  • Cihan Kurt
    January 9, 2018 at 6:55 pm
    I’m using this external drive right now. https://www.amazon.com/gp/product/B01N7QFZLQ/ref=od_aui_detailpages00?ie=UTF8&psc=1 But if necessary I can get one ssd too. Could you tell me which way to follow? What is the best method for disk?
  • Robert Withers
    January 9, 2018 at 7:12 pm
    Despite Adobe’s self-promotion about working with all formats, I convert everything into ProRes to edit in PrP, including iphone footage. (That said, I’ve never worked with iphone 60fps, only the approximately 30fps that my old iphone generates.)
    Transcoding avoids a lot of problems.
    Also you can try reducing playback resolution.
    Robert
    Robert Withers
    Independent/personal/avant-garde cinema, New York City
  • Cihan Kurt
    January 9, 2018 at 7:36 pm
    Could you elaborate more? They have ProRes formations. Which is the best for 1080p 60 fps?
