Activity Forums Adobe Premiere Pro Premiere Pro is shutting my PC down on export
  • Premiere Pro is shutting my PC down on export
    Posted by Chad on June 11, 2005 at 8:01 pm
    Hello,
    I am having an issue with exporting via Adobe media Encoder. It seems to be on just one sequence that I am trying to export. All the other sequences exported with out any problem.
    Does any one know what the problem could be? About 75% thru the process it just turns my computer off completly.
    If you need any more details please let me know.
    Regards,
    Chad
    R. Hewitt replied 21 years, 3 months ago 3 Members · 3 Replies
  • Rj Hewitt
    June 11, 2005 at 9:49 pm
    Chad, this sounds like a problem I had until recently with Adobe Encore DVD.
    Encoding is an extremely processor intensive task and usually runs the CPU flat out. This in turn increases the temperature of the processor. Many motherboards are designed to shut your system down when the heat sensor under the processor reaches a preset temperature. That’s exactly what mine did. It only ever occured while encoding. Fitting a larger heatsink and fan solved the problem for me even though it was originally fitted with the standard, supplied AMD heatsink and fan.
    There aren’t many other things that will switch your PC off so suddenly.
  • Chad
    June 12, 2005 at 1:19 am
    wow, that did the trick! Thank you so much. I am using a laptop so it doesnt get to much room to vent. I sprayed a thing of can air on it during the rendering process and walla!
    Thanks very much!
    Regards,
    Chad
  • R. Hewitt
    June 13, 2005 at 4:52 pm
    That’s good news it cracked the problem Chad. I guess the internal cooling wasn’t designed for the processor to work as hard as rendering pushes it.
