Activity › Forums › Adobe Premiere Pro › Premiere Pro, HDV and a Hardware Output??
  • Premiere Pro, HDV and a Hardware Output??
    Posted by Brett Howe on November 23, 2005 at 1:12 am
    Hi Bovines
    Currently our online edit solution is a Leitch Velocity, realtime, uncompressed joy…but getting a little old in the tooth!
    I am intersted in moving over to a Premiere Pro solution if the price is right, and the hardware and software integration is up to the task.
    I would like to be able to cut HD/HDV, but of course still have SD as an option. I need the full set of outputs. SDI, Component, Composite etc.
    Obviously an SD monitoring option of the HD timeline would be nice!
    Any thoughts?
    Marc Bauwens replied 20 years, 10 months ago 4 Members · 6 Replies
  • Larry Sherwood
    November 23, 2005 at 4:16 am
    Check out Matrox Axio, HD & SD editing, broadcast quality real time effects, real time down-convert from HD to SD for output . . .
    LS
    Larry Sherwood
    Sherwood Post Production
    Austin, Texas
    512 219-8721
    larry@sherwoodpost.com
  • Marc Bauwens
    November 23, 2005 at 7:29 am
    We have a workstation built around the Blackmagic design HD card with an external breakout unit from the same company.
    Great value, great product, but not sure how it compares in terms of price to the Axio.
  • Mike Smith
    November 23, 2005 at 9:24 am
    Any reason why you’re not interested in Velocity HD ..?
  • Brett Howe
    November 24, 2005 at 12:25 am
    Although the Velocity has been great, and is still rock solid, there are issues. Cost being one of them. The Leitch gear just isn’t price competative here (AUS) anymore. (IMO).
    There are lots of SD & HD options out there now.
    Also format is an issue. We outsource alot of segment production, and it would be nice to use a format we can drop on the timeline. QT or AVI based.
    We have the Leitch DPS file exporter for windows, but it’s buggy, unpredictable, and on some systems, just doesn’t work at all!
    We also have just purchased a very grunty P4 laptop for field use, and would like to integrate the work from this unit into our online gear. Currently this is a very slow process with the velocity.
    I’m just looking at options currently. I feel like hardware solutions are really only for IO in the near future, as PC power increases.
    Brett
  • Mike Smith
    November 24, 2005 at 1:15 pm
    Thanks. Cost is always an issue, and I think you must be right on hardware being mainly for IO, at least at some time in the future. Not sure we’re totally there yet, though, even for SD – on a fast twin xeon based system, I still have more rendering time than I’d like with Premiere. I guess that must be even more so with HD.
    I had a Perception for a while, which was beautifully stable and very nice quality. I really liked the ability to work on single frames so easily – but otherwise, integration was difficult. Also the ability to set capture compresssion to suit was a big plus.
    Currently I have a Decklink SD board, which produces very good results and has been stable for me, though the drivers are evolving almost month by month, and you’ll have seen there have been some issues for some users. PPro has some really nice features, and integrates well into wider computer software. You’ll also be aware that some editors don’t like its asset management, and handling split audio track input at present involves a workaround, but neither of these have bothered me.
    I’m not at all sure how well Decklink will deal HDV, though. The only good HDV out in realtime from a timeline I’ve seen to date was via a Canopus Edius SP system, which probably won’t talk to a Decklink. I understand that Premiere is improving in that regard HDV handling, though best by use of a third-party plug in – Cineform Aspect HD – which has the benefit, I believe, of replacing PPro’s internal 8-bit processing with a 10-bit version …
    My guess is that, today, with Decklink, you’d be capturing HDV via component inputs to uncompressed HD – massive disc space requirements, though very nice quality.
    So if HDV is a prime target for you going forward, maybe it would be worth checking with BlackMagic what their suggested workflow would be for you? I wonder whether Decklink on a Mac capturing HDV via firewire might be a stronger option for you than PPro …
    All best.
  • Marc Bauwens
    November 24, 2005 at 6:02 pm
    Plus the fact that Blackmagic is an Aussie company and the service is outstanding !!!
    They are very proactive, especially with drivers.
    ANd they select the distributors very well.
    Here in Belgium nothing but good experiences with Blackmagic, plus the fact that almost EVERY small shop here is eqquipped with a Blackmagic card (PC or MAC)
