Activity Forums Adobe Premiere Pro Premiere pro glitch
  • Premiere pro glitch
    Posted by Justin Gordon on May 4, 2005 at 10:00 pm
    I put up a post a while back about a glitch that caused my entire workspace to disappear into the bottom bar of the window. No help from adobe expert support and i’ve rest the prefs, cascading the workspace does nothing but luckily i’m able to save my work close the program then rerun and it works fine until i make some sort of action (which has no pattern that i’ve seen) then it does it again. 4 hours of working, it usually happens 3 times. Sometimes it will happen repeatedly within 5 or 10 minutes of opening premeire. That’s when i shut the beast down and have a smoke. Thanks.
    https://www.msu.edu/~gordon21/pictures/glitch.gif
    Aanarav Sareen replied 21 years, 4 months ago 4 Members · 3 Replies
  • Tim Kolb
    May 4, 2005 at 10:17 pm
    Now that is a goofy problem…and no doubt frustrating.
    Since I haven’t seen behavior like this often…or at all, myself…what’s your configuration? Are you running the display card at the upper end of its resolution capabilities? Any weird blankers on your system? Has PPro ever worked without this glitch? If it did, is it possible for you to track what changed on the computer around the time you noticed this?
    TimK
    Kolb Syverson Communications
    Creative Cow Host
    2004, 2005 NAB Post Production Conference Premiere Pro Technical Chair
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Steven L. gotz
    May 4, 2005 at 10:43 pm
    Can we assume that selecting a standard workspace does not restore it?
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Aanarav Sareen
    May 5, 2005 at 1:34 am
    Looks like a case of spyware or someother malware on your system. Have you tried running anti-spyware programs?
