Activity Forums Adobe Premiere Pro Premiere Pro glitch, JVC glitch, or (most likely) User Error?
  • Premiere Pro glitch, JVC glitch, or (most likely) User Error?
    Posted by Anthony Popolo on July 29, 2025 at 5:44 pm
    I recently bought a GY-HC500 for 4k shooting of live events, which are normally continuous recording for at least an hour. I’ve used JVC cams for over 20 years and Premiere Pro for about 5 years (and FCP for 20 yrs before that) and have not run into this issue before. My typical shooting setup is plugging live room mics into camera, as well as recording a separate audio source (from soundboard, e.g.) into a stand alone Tascam DR60 digital recorder. I slate the audio at top of show so I can sync them in PPro.
    For my first project using this 4k camera, the two audios drifted about 8 frames over an hour program, which is very noticeable to the ear by the end (echo). Thinking it must be camera settings, I checked all the settings that I can think of and they seemed compatible. It doesn’t appear to be a drop/non-drop frame issue, or a sample rate issue (both at 48k). I also looked at 30fps vs. 29.97fps timebase in PPro. Didn’t seem to matter (camera menu doesn’t have a 29.97 option, just the nominal 30).
    I’ve zeroed in on something odd, but I don’t know where to go from here.
    Because of the 4GB limit on files (3.71GB), I get multiple sequential clips (files) out of the camera when I record longer programs. In this case, I got 16 sequential clips for a 1 hr program. When I created the blank timeline to start, I wasn’t confident about specific settings so I guessed from the options and sure enough, when I dropped the clips into the timeline, there was a mismatch between timeline and clip settings. So when the dialog box popped up and alerted me, I selected the “change sequence settings” to match clips. So I thought I was covered.
    After I laid the 16 clips in, 8 of them didn’t visually appear to be the complete clip. They’re missing that little triangle in the upper right hand corner. See attached image. I moved the subsequent clips later on the timeline and was able to expand the partial clip by 1 frame to its full length (revealing that end-of-clip triangle), but that one frame has no video or audio (see image zebra). Without that frame, the video runs smoothly, so it looks like Premiere Pro removed that black frame on it’s own when I put it in the timeline. However, that missing frame now makes its linked audio shorter than my 2nd audio source, resulting in an accumulating one frame drift each time that happens. The audio connected to the video is in still in sync with the video image, but not with the 2nd audio.
    As a workaround, I tried to use the rate stretch tool (keyboard-R) on the 2nd audio to make it match to the end. It sounds good on timeline, but when I export mixed audio, the drift is in the exported audio!
    Any ideas on what’s going on? Am I missing an import step perhaps?
    Mads Nybo jørgensen replied 1 year, 1 month ago 4 Members · 5 Replies
  • Rob Ainscough
    July 29, 2025 at 6:12 pm
    Yikes! That seems like a lot of work. Just so you know, the GY-HC500 when using XDSC card, you can turn OFF file spanning which will support up to 64GB file size.
    I know that doesn’t really answer your question, but for future reference it will hopefully allow you to avoid this extra workflow.
  • Anthony Popolo
    July 29, 2025 at 6:52 pm
    Thanks Rob,
    I didn’t know that option existed. The fewer clips the better! I will try that on my next shoot for sure.
  • Rob Ainscough
    July 29, 2025 at 8:46 pm
    I believe the option is only available for XDSC storage cards on that camera. Sorry I couldn’t help with Pr … has been a while since I used Pr and had multiple 4GB clips on a single run … but I thought Pr has feature to automatically sync separate audio clips once you detach tracks from video?
  • Bob Gale
    July 30, 2025 at 1:56 pm
    I know it’s not really a fix, but can you add a frame hold for that one frame so you don’t see a flash of black? Just a thought.
    July 30, 2025 at 2:03 pm
    Hey Anthony,
    How frustrating!
    Sorry, that you have to go through this, but Adobe is currently not treating PPro with the respect that it deserves.
    You didn’t tell us what file format you were shooting.
    But assuming that it is MP4 LongGop, and that is why you are missing frames etc – I’ve just been through that on PPro v25.
    I suggest that you as a test take the “first clip” (file) and transcode into a stable format with each frame being a full frame. Yes that will cost you space on the hard-drive + export time, but at least if it works, you know where the problem is.
    ProRes is stable, there is other formats too that Adobe can offer you.
    The US JVC website is not clear on whether it is 29.97P or 30P, but in theory PPro should have chosen the frame-rate that you shot it at.
    If there is an XML file that came along with the video-file from the camera, it might be worth you opening that and see what it tells you?
    Otherwise, in the transcode, depending on what your Tascam DR60 digital recorder fps was set to, maybe match that if you can?
    Hope this helps you getting a bit closer to a solution.
