Activity Forums Adobe Premiere Pro Premiere Pro external monitor
  • Premiere Pro external monitor
    Posted by Tip Mcpartland on September 26, 2005 at 11:57 pm
    Thanks to Hector, but I haven’t been able to make his suggestions work — perhaps my computer won’t do it. But if anyone knows how to make an HP Media computer get an external monitor to display just the video program, I would be very appreciative.
    Thanks in advance,
    Tip
    Tip Mcpartland replied 20 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Mark Perez
    September 27, 2005 at 4:00 am
    After almost 2 years, I have asked here a dozen times, with no results, or what works.
    There is no built in option in PP to have it pushed up to a monitor, the only option you have is firewire out, to converter, to s-video/RCA. Pick your flavor of how to do it.
    cheapest, use your camcorder
    $$$ canopus 100 or similiar
    $$$$ high end matrox or similiar
    after 30 hours wasted trying to get this to work correctly, my little sony camcorder fires it up everytime. just my home model, and the better cameras are used for the jobs.
    If you find a solid solution, please post it loudly
  • Steven L. gotz
    September 27, 2005 at 3:42 pm
    Which video card does it use?
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Lkj
    September 27, 2005 at 6:14 pm
    Hey Tip,
    I’m getting ready to let go of my DA-MAX+. It’ll give you SDI/Component/Composite/SVHS/1394 i/o. I used it with the full DS
    in the Razor days. Interested?
  • Tip Mcpartland
    September 28, 2005 at 1:09 pm
    Steven,
    The display adapter is a Radeon X300, which I suspect is built in to the MB, but I really don’t know.
    The computer is an HP 830 with a Pentium D at 3GHz. The OS is XP Media Edition and supposedly it can record and play back TV. It has S-Video and composite video outs. I continue to suspect that because of the above, somehow it can play video out of PP, but so far no luck.
    Thanks for your interest in my problem.
    Tip
  • Steven L. gotz
    September 28, 2005 at 1:46 pm
    Perhaps this will help, perhaps not.
  • Tip Mcpartland
    September 29, 2005 at 3:46 am
    Steven,
    Thank you so much for taking the time to post this. I am at work in LA so I can’t try this until tomorrow night. I’ll let you know if this does it, but whether or not it does, my gratitude will be the same!
    Tip
  • Tip Mcpartland
    September 30, 2005 at 5:59 am
    Steven,
    Thanks, but I don’t think my crummy video card supports one of the steps. When I get to the Overlay tab there is no clone mode option. It lets me go sraight to the box to select theater mode. The aspect ratio stuff is there. Finally I can’t find where to select Primary and Feature monitors. In my “big” editing system which has a Parhelion it is very easy. This probably hard primarily because it’s impossible! Thanks again for giving it the old school, or is that the old forum, try!
    Tip
