Activity Forums Adobe Premiere Pro Premiere Pro – exporting issue
  • Premiere Pro – exporting issue
    Posted by Pfish on April 19, 2005 at 4:09 pm
    Hi there,
    I wonder if it is possible to export timeline as a multiple avi files at once? I mean that every cut would be exported as a separate avi file.
    Is this possible? If so, how? 🙂
    I need to export edited material, approx. 200 cuts, each cut as separate avi file.
    Hopefully this is possible.
    Dex Craig replied 21 years, 5 months ago 2 Members · 1 Reply
  • Dex Craig
    April 19, 2005 at 10:43 pm
    I’m not sure what you’d need to do this for, unless it’s to move the material into, say AfterEffects to put effects on each individual shot, and you don’t want to render out the untrimmed clips.
    If that’s the case, you can import the Premiere project into AfterEffects as a project and the trims will be applied to the clips in the AE timeline.
    If that’s not what you’re trying to do, I’m sorry, but I don’t have any ideas. Sorry!
    HTH
    Dex
