Activity Forums Adobe Premiere Pro premiere pro export to encore
  • premiere pro export to encore
    Posted by Erik Curtis on June 15, 2010 at 3:14 pm
    I have created a project in premiere pro that has audio and video on track 1. I’ve added music to track 2. Everything plays fine in premiere pro. When I export to encore and create a DVD, the audio from track 1 does not play. Is there a way to mix the two tracks when exporting to encore?
    Erik Curtis replied 16 years, 3 months ago 2 Members · 4 Replies
  • Jeff Pulera
    June 15, 2010 at 3:28 pm
    Hi Erik,
    ALL the tracks should export by default, not sure why there’s an issue if all audio tracks are active and playing back in Premiere.
    A quick fix might be to do File > Export > Audio, or for newer versions use Adobe Media Encoder, to export a .wav file of the timeline mix, then place the mixed clip on track 3 and mute tracks 1 & 2 before export to Encore.
    Jeff Pulera
    Safe Harbor
  • Erik Curtis
    June 15, 2010 at 3:36 pm
    Jeff,
    Thanks for the fast reply. One thing I’ve noticed when I use the “send to encore” option, there is only one audio track shown in the encore timeline. Seems that I should see the two tracks like they are in premiere.
  • Erik Curtis
    June 15, 2010 at 3:52 pm
    In my original post I said “When I export to encore and create a DVD, the audio from track 1 does not play”. when actually it is the audio from track 2 that does not play.
  • Erik Curtis
    June 18, 2010 at 3:11 pm
    Update- I found the fix! The problem was between the chair and the keyboard. Somehow I muted the audio on track 2 just before sending the project to Encore. Lesson learned, don’t overlook the obvious. Once I un-muted track 2, everything worked.
