Activity › Forums › Adobe Premiere Pro › Premiere Pro export resolution
  • Premiere Pro export resolution
    Posted by Clinton Sturges on February 16, 2011 at 2:49 pm
    Hello all, this is my first post here, hopefully I can be a helpful part of the community as I learn more, for now I have a Premiere question.
    I set up my video to be 1280 x 720 but when I go to export it the default is a different resolution.
    When I set the format to MPEG4 it defaults at 176 x 144 and 15 fps. When I try to increase the frame size I get the error “Invalid framesize/framerate for this level. Please lower the frame dimensions, frame rate or increase the Profile and Level and try again.” I try to change the level and profile, but whatever I seem to try I keep getting the same error.
    When I set the format to Quicktime it defaults to 720 x 480, and the resolution is greyed out so I can’t try to edit it.
    What I need is the output to be the same pixel size that I created the project at…1280 x 720.
    Thanks in advance
    Nick Bussey replied 13 years, 4 months ago 3 Members · 2 Replies
  • Jeff Brown
    February 16, 2011 at 8:58 pm
    MPEG 4 has different “levels” Level 1 through 3 are limited to small images (as you found). Try Level 5, that should let you do full HD.
    QuickTime defaulted to 720×480 because you has NTSC-DV selected. Only one frame size allowed for that format (DV).
    hope it helps,
    Jeff
  • Nick Bussey
    May 17, 2013 at 12:48 pm
    My levels only go up to 3 and I’m having the same problem trying to export to DVD in MPEG4
