Activity Forums Adobe Premiere Pro Premiere Pro export a corrupted file without giving errors.
  • Premiere Pro export a corrupted file without giving errors.
    Posted by Michele Poggi on May 29, 2014 at 6:18 am
    Hi guys, I really need your help. I should get a work done for today, and I rendered the sequence three times with the same results.
    Nothing is changed from my old ones, so I can’t understand what’s happening. The sequence is 29,97fps, all the sources has the same fps, it’s 1h long at 1280*720, and I’m exporting in h.264 14MBps.
    AME renders it OK, it gives the signal of completition but then the file instead of being 7GB it weights 1.4 and it’s corrupted.
    I don’t know what to do honestly.
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Michele Poggi replied 12 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
