Activity Forums Adobe Premiere Pro Premiere Pro distorts voiceover
  • Premiere Pro distorts voiceover
    Posted by Deana Muro on August 27, 2023 at 12:29 am
    Hey there. Could really use some help. I’m working on a 30 minute video and have done several voiceovers without incident. Now, suddenly, when I record, it makes my voice sound several pitches lower. Help?
    Santanu Bhattacharjee replied 3 years ago 4 Members · 3 Replies
  • Dennis Dean
    August 27, 2023 at 2:11 am
    I would get out of Premiere and record the track in Audition or the free app – Audacity. Export as a wave file and import into Premiere. Alt – open a new project in Premiere, record a few lines and see if you have the same problem. Export as WAV file and see if it sounds ok when played through another app, such as QuickTime. I don’t record directly into Premiere Pro. I used to use Audacity, now I use Audition. Both are excellent. Good luck!
  • Bill Celnick
    August 27, 2023 at 12:28 pm
    Agreed – I record all of my narration via Audition and import back into Premiere as a wav as well.
    I think I did it this way since before Premiere had VO capabilities and saw no need to change my process.
  • Santanu Bhattacharjee
    September 17, 2023 at 10:27 am
    Check the clip property in Interpret footage. A sample rate change or misinterpretation may be creating the pitch change.
    http://www.santanu.biz
