Activity Forums Adobe Premiere Pro Premiere Pro Dissolve Issues
  • Premiere Pro Dissolve Issues
    Posted by Curtis Cosby on October 31, 2014 at 12:44 pm
    Hello All,
    I wanted to see if anyone has ran across this same issue and if it is a bug or am I doing something wrong.
    I created a multicam sequence and bumped it up against my intro. I have plenty of extra frames for the dissolve ( I have tried an cross dissolve and a film dissolve) both have the same issue. When I add the dissolve some how it fades out from the intro perfectly fine but when the fade in starts it uses frames from about 10 seconds into the clip, then once the dissolve is finished it jumps back to the first frame of the actual clip.
    Anyone have any thoughts or ideas, it seems to be just with Multicam the dissolves work on a normal clip?
    Curtis Cosby
    Multimedia Assistant
    Curtis Cosby replied 11 years, 10 months ago 2 Members · 2 Replies
  • Tim Kolb
    November 1, 2014 at 6:16 pm
    What happens if you leave the dissolve in place and save the project and look at it again?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Curtis Cosby
    November 5, 2014 at 5:27 pm
    Sorry Tim, I just saw this reply. It still has the same behavior. I was able to get the project edited and out without using multicam. It was very short but I need to have the functionality in the future. I have tested in on other projects and it does the same thing. This has only happened since updating to the latest version of CC.
    Curtis Cosby
