Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6-very sluggish
Posted by Phil Mastman on February 10, 2013 at 3:36 amPremiere Pro’s interface is suddenly acting very sluggish on my 12-core 64GB Mac Pro. Adding a new bin will cause the spinning beachball for over 30 seconds. Importing a single clip or moving one from one bin to another takes forever. Same for duplicating a sequence. I’ve tried trashing prefs. No change. Any ideas?
–Phil
Kevin Monahan replied 13 years, 7 months ago 3 Members · 6 Replies -
Tom Daigon
February 10, 2013 at 3:08 pmHave you tried the standard approach for resolving quirks in PrP?
1. Trash Prefs.
2. Repair Permissions.
3. Delete Media Cache.
4. Open new sequence and copy/paste old one into it.Try each step and test system before moving to the next. Good luck!
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Phil Mastman
February 10, 2013 at 7:58 pmProblem solved. Turns out that Pr does not like having several large JPEG sequences in a bin. I removed the sequences (about 7000 individual JPEG frames), and now Pr is zipping along as normal. Better to convert those frame sequences to a movie before bringing them into Premiere.
–Phil
Tom Daigon
February 10, 2013 at 8:00 pmGood to know.
Tom Daigon
HP Z820 Dual 2687
64GB ram
Kevin Monahan
February 12, 2013 at 12:06 am[Phil Mastman] “Turns out that Pr does not like having several large JPEG sequences in a bin.”
How big was the frame size for the JPEGs? You can resize them before bringing into Premiere Pro.Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Phil Mastman
February 12, 2013 at 4:13 amKevin, the jpegs were 1920×1080. Not huge. Just too many of them for Pr to handle.
Kevin Monahan
February 12, 2013 at 10:17 pmOdd. Premiere Pro should be able to handle large image sequences. I’ll try to reproduce the problem.
Kevin Monahan
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
