Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6 Titles not updating
  • Premiere Pro CS6 Titles not updating
    Posted by Butch Madey on June 7, 2012 at 1:43 pm
    Here is the scenario
    In Premiere Pro CS6 open a new project (any size etc.)
    Go to title new
    Do not name the title just click ok (the program will name it title 1)
    Create a title and close the titler.
    Drag the new title from the project panel onto the time line.
    You should see it’s name as – “title 1”
    In the project panel click on “title 1” to change it’s name
    Change the name to anything you like.
    NOTICE it does not change the name in the time line. It does not update the name change you make in the project panel to the title in the time line.
    Is this a bug in the program?
    Butch Madey
    Flying Rhino Pictures
    Paul Neumann replied 14 years, 3 months ago 3 Members · 2 Replies
  • Ann Bens
    June 9, 2012 at 8:02 pm
    No not a bug but as designed.
    If you want to have the name changed in the TL also rename in the timeline or Replace with clip from bin.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Paul Neumann
    June 10, 2012 at 2:45 am
    If you duplicate a title in a Bin and then rename it the new name will follow it when you put it in the timeline. Pretty much the name you give it when it’s born is the name that’s going to have once it hits the timeline. Makes sense given how you need the right data to follow that title for a unique instance and protects it from accidental renaming in the Bin.
