Activity Forums Adobe Premiere Pro Premiere Pro CS6 Title Bug ?
  • Premiere Pro CS6 Title Bug ?
    Posted by Paul Jones on October 21, 2012 at 7:40 pm
    Hello
    I have recently switched from FCP7 to Premiere Pro 6.
    I have been using it for about a month with no problem but stumbled across one yesterday.
    I am working on a project which I backed up using project manager so I can continue to work on the project at home this weekend.
    The problem I found was in the title tool.
    In my original project I had created about 15 titles, each on I had used “New title based on current title’ and just re-typed the new title to match the previous one.
    When I tried this from the project backup at home the copied titles were different aspect and size to the original.
    I manually adjusted the settings to match my previous titles, but when I export the film the titles are a different size again on the Quicktime.
    To get round this, I had to create the new titles in After Effects and import them in which worked fine.
    I’m also using standard Helvetica, so it’s not a problem with not having the same font on my Mac Pro and Macbook Pro
    I understand if this is a simple error as I’m a newbie to PP but would be interested in any feedback why this is happening.
    Thank you
    Paul
    Alex Lundquist replied 13 years, 9 months ago 2 Members · 1 Reply
  • Alex Lundquist
    November 30, 2012 at 1:42 am
    I had this same Problem. Had to create separate titles for each still frame in a 300 frame sequence. Everything I tried had similar issues. I tired duplicate or create a new title based on template. It would be slightly different in size.. or kerning.. This was a deal breaker for me in Premiere Pro. I switched back to Final Cut X to do this project in. Which I hate…but this has made using Premiere useless for me…..
