Premiere Pro cs6 template animation or by keyframes?
Dear all,
I am new in premiere pro cs6. I want to animate several clips and images that will appear in different times and space on screen, and will play separately(different times. I uploaded two screen shots as example of what I need to do.
I was told that there is a template already in premiere pro cs6 that I could use for this…but can’t find it anywhere, I was wondering if someone can tell me if this template exist or I have to do all with keyframes in premiere for space/positions/opacity/time etc, if so, will you animate this in premiere or is better to import the animation from after effects into premiere? I am new on premiere but if it works as AE I guess I just do all my keyframes animations in premiere?
Thank you all!
