Activity Forums Adobe Premiere Pro Premiere Pro Cs6 – Sync lock
  • Premiere Pro Cs6 – Sync lock
    Posted by Alex Olinger on October 21, 2013 at 11:46 pm
    Hello,
    I`ve been recently switching over from Avid to Premiere CS6 and I have been having some trouble with the ripple edit tool and its relationship to sync lock.
    In Avid when you do a ripple edit to a clip, if there is any music/sfx audio beds underneath that edit, it will split that track to push all content downstream to maintain sync.
    With Premiere, I see that the program with push content downstream in a similar way, but it will not split any audio beds if need be. I`m seeing that this could be a problem as I would have to readjust SFX sync multiple times downstream.
    Is there anyway to tweak this behavior inside of Premiere?
    Thank you.
    Alex Olinger replied 12 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
