Activity Forums Adobe Premiere Pro Premiere Pro CS6 serious glitching.
  • Premiere Pro CS6 serious glitching.
    Posted by Brian Macaione on April 22, 2013 at 8:49 pm
    Hello, I’m running Premiere Pro CS6 and having a serious problem. I’ll try to explain it as basic as I can as it’s kind of complicated. Say I bring in a clip of just red solid color and cut that clip into 5 separate clips. And then I bring in a clip of just green solid color into the time line. If I then play it, for some reason the last frame of all the red clips will be the green clip. So playing it would look like red clip > single frame of green > red clip > single frame of green ect. I cut an entire video with out having this problem then went back to make changes and it popped up once. Now the second video I just began cutting it has been there since the beginning. The single frame seems to embed itself into the other clips and even if the original clip is shortened or lengthened it stays at the end. Any help would be great, thanks.
    Antonio Marshall replied 12 years, 6 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    April 22, 2013 at 9:22 pm
    Post a screenshot of your timeline, and let us know what GPU you’re using if you’re using GPU acceleration.
    For now also go to Sequence > Delete Work Area Render Files (if not grayed out) and then go to Sequence > Render entire work area. My initial assumption is that it’s a playback glitch – this happens every so often.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Brian Macaione
    April 22, 2013 at 9:47 pm
    I tried deleting render area and unfortunately I did not help. I do not know what GPU acceleration is so I can not tell you if I am or are not. I’m cutting on a 2012 MBP with CS6 if that helps. I’ve included a snap shot that shows the mysterious frame which as you can see from the snap shot not only shows up at the end of every clip, but also whenever it feels like it as there is no clip where the play head is and yet the clip remains.
  • Brian Macaione
    April 26, 2013 at 4:41 am
    So I ended up scrapping the entire project and started a new one. 3 clips into it, it starts doing this again. I’ve even switched from 4 to 16GB’s RAM in the mean time and it did not resolve the problem. Any ideas? I’d cut on FCP, but it can’t handle the MTS files with out transcoding so I’d like to stick with CS6 which can save for this insufferable glitch.
  • Antonio Marshall
    March 4, 2014 at 7:29 pm
    I was wondering if you had any luck fixing the glitches….
