Activity Forums Adobe Premiere Pro Premiere Pro CS6 Scopes not Updating
  • Premiere Pro CS6 Scopes not Updating
    Posted by Scott Devlin on January 15, 2013 at 9:50 pm
    I am trying to do color correction in Premiere CS6, and my scopes will not reflect the changes I make to the clip. The scope will update as I drag through the timeline, but no effect changes are reflected in the scopes. Ideas?
    Ryan Paterson replied 13 years ago 2 Members · 2 Replies
  • Ryan Paterson
    August 22, 2013 at 7:33 pm
    Did you ever find a solution for this? I’m having the exact same problem
  • Ryan Paterson
    August 22, 2013 at 7:36 pm
    Nevermind, I figured it out! You have to use the scopes in the “Reference” window, not the “Source” window
