Activity Forums Adobe Premiere Pro Premiere pro cs6 scene detection
  • Premiere pro cs6 scene detection
    Posted by Josh Phoenix on March 26, 2013 at 12:13 pm
    I am having video files compiled in a sequence without cuts or edits then exporting this as 1 media file to help with bandwidth on sending the file and also to know the rough order of the clips. Is there an easy workflow for having some scene detection and converting this footage back to the original clips so I may edit in premiere? I do not own speed grade, and it is not available for trial for me..
    I can do this process in Davinci, but was seeing if premiere has a strong option or if EDL or XML may be the route to go?
    Any guidance is very appreciated.
    Thank you
    Paul Levin replied 11 years, 10 months ago 3 Members · 2 Replies
  • Jeff Greenberg
    March 28, 2013 at 3:02 pm
    Premiere has no shot detection ability. You’d have to figure out (with your budget) some workflow in Resolve to make this work…
    Or take your original NLE and do a consolidation with handles (say 10-20 frames) and send an XML/AAF to Adobe Premiere Pro; you’ll increase the size and make it harder to handle than one file – but editorial systems aren’t really meant to edit a single file.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Paul Levin
    October 29, 2014 at 8:51 pm
    Well, I came across this a year or so late, but anyone else having this problem, I found this script for after effects works nicely, if that helps.
    https://aescripts.com/magnum-the-edit-detector/
