Activity Forums Adobe Premiere Pro Premiere Pro CS6 Ripple Delete Problem
  • Premiere Pro CS6 Ripple Delete Problem
    Posted by Paul Jones on September 26, 2012 at 3:04 pm
    Hello…..one more thing…
    I’ve had my first try on Premiere Pro 6 today and I’m getting used to it already (moving from FCP7)
    One problem I can’t resolve is marking in and out points on the timeline and trying to ripple delete like you can so easily in FCP.
    I’ve been told it’s shift delete but nothing works.
    I’ve tried on my Macbook Pro and my MacPro and the same problem on both.
    I have also checked the keyboard settings are correct.
    Any help really appreciated
    Thank you….
    Vijay Kumar replied 10 years, 9 months ago 6 Members · 5 Replies
  • Tom Daigon
    September 26, 2012 at 4:03 pm
    PrP doesn’t function in that manner. You need to razor the in and out points then do the ripple delete.
    Feature requests can be made here…
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Mark Maness
    September 26, 2012 at 6:29 pm
    The keyboard shortcut to Ripple Delete is: Option-Delete
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Gregg T. karr
    September 26, 2012 at 6:44 pm
    Actually, that does not work with an IN and OUT set in the timeline. That only works with “selected” clips in the timeline. To perform a “ripple” edit with and IN and OUT set, you have to hit the “extract” key. (it’s the comma, quote key).
    Just make sure you all your video and audio tracks are patched. Or even better, patch which tracks you want to ripple delete.
    Now if only the “markers” would ripple delete too. A good feature request for all readers.
    Hope this helps…
  • Brian Kessler
    July 9, 2013 at 6:10 am
    Just hit ‘
    (no modifier key)
  • Vijay Kumar
    December 14, 2015 at 12:07 pm
    How to do a ripple cut in Premiere Pro CC
    Select a clip or Select a portion of a clip with IN & OUT.
    Extract it with ( ‘ ) Apostrophe Command
    And paste it with Cmd+V for over write edit or use Cmd+Shift+V to do an insert edit.
