Activity Forums Adobe Premiere Pro Premiere Pro CS6 project files in previous verions of Premiere
  • Premiere Pro CS6 project files in previous verions of Premiere
    Posted by Emmanuel Todorov on November 8, 2012 at 9:52 pm
    Hey everyone,
    I was looking online to solve an issue I had with my workflow where I had an editor work in PREMIERE PRO CS6 and I was using the previous version of PREMIERE PRO CS5.5
    As several users had posted here in this forum, one is unable to open Premiere Project files from CS6 into Premiere Pro CS5.5, BUT…
    I found out through testing that you can open Premiere Pro CS6 files in Premiere Pro CS5. then you can import them into Premiere CS5.5 – a bit of a workaround but if you will need it it is there !!
    I hope I have helped somebody with this post.
    Thank you for posting guys.
    Emmanuel Todorov replied 13 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
