Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6 Preview Render
Posted by David Tunnell on May 20, 2012 at 2:31 pmI have only recently started using Premiere Pro for serious video editing. I am a little frustrated by the need to do preview renders to get smooth playback. It takes forever with HD footage and is slowing me down. Is there a way to avoid having to do that?
I don’t have to do preview renders in Sony Vagas, but I like the feature set in Premiere Pro Better.
David Tunnell
TunnellVision ProductionsBrian Cheng replied 12 years, 5 months ago 3 Members · 11 Replies -
Jeff Greenberg
May 20, 2012 at 2:32 pmHave you tried reducing the playback resolution?
Best,
Jeff I. Greenberg
Editor/Author/Speaker/Consulting
My NAB seminar schedule, contact info and more -
David Tunnell
May 20, 2012 at 2:37 pmNo, as I said, I am a newbie and I didn’t know you could do that? Is that like After Effects where the image quality gets reduced quite a lot?
David Tunnell
TunnellVision Productions -
Jeff Greenberg
May 21, 2012 at 12:25 amRight click the Program monitor (or look under the wrench).
This reduces quality only during playback – the paused resolution is full quality.
I used to cut picture at very low quality; this is miles above it.
It’s similar to AE’s 1/2 or 1/4 res; but the moment you pause, full quality.
David Tunnell
May 21, 2012 at 2:00 pmI did that and still got some lag. I am beginning to suspect that it is a combunation of factors. One being that I am using an external USB drive. It is USB 2.0.
David Tunnell
Jeff Greenberg
May 21, 2012 at 2:55 pmAn easy way to test the drive speed is with Black Magic or AJA’s disk test.
Best,
Jeff I. Greenberg
David Tunnell
May 21, 2012 at 4:26 pmGetting 15.16ms access, max read 22.02 MB/sec Max read 39.20 MB/sec cached. Overall Score 99.5??
David Tunnell
Jeff Greenberg
May 21, 2012 at 4:36 pmI never did ask. What format and how many streams of it are you trying to playback? Did dropping the quality help? Is it at 1/4?
Best,
Jeff I. Greenberg
David Tunnell
May 21, 2012 at 4:52 pmIt was one video that is 1080i. It was an uncompressed .avi. In the standard def world, .avi’s were less problematic.
I only have options for full, 1/2 and 1/4. 1/8 and 1/16 are greyed out.
Lately I have been changing to High Quality .h264 video out of after effects. For some reason I just can’t get decent reults with .mov files???
In the last few months I have been experiemtning with the best formats for HD. I do a LOT of After Effects work that I then render out to do final editing and post in Premiere Pro.
David Tunnell
Jeff Greenberg
May 21, 2012 at 6:14 pmUnless you’re over HD, you’ll only get 1/2 and 1/4.
If you’re working with After effects, either render as a editorial codec HD (such as ProRes or DNxHD), especially if you want to keep your alpha channel. Adobe Premiere Pro can dynamically link to AE – so you don’t need to render for Premiere Pro (from AE. You may want to render in Premiere Pro for playback.)
Also, an uncompressed AVI, will require a drive speed of around 100 MB/sec (over 800mb/s.). You’d need 4 of your drives RAIDed together to get that.
Best,
Jeff I. Greenberg
David Tunnell
May 21, 2012 at 7:30 pmI had no idea about dynamic link! I had seen it, just ran a test, premier has to render it to be able to use it and that render is almost as long as just outputting the file.
I wonder if you could expand a bit on “editorial codec HD (such as ProRes or DNxHD)”
I don’t see those opetions in AE’s render format options. I saw a tutorial where the guy used a “Video Stream” from the export function, but I don’t see that in AE CS6 export.
David Tunnell
