Activity › Forums › Adobe Premiere Pro › Premiere Pro CS6 Not Importing MFX files from Panasonic 370 P2
  • Premiere Pro CS6 Not Importing MFX files from Panasonic 370 P2
    Posted by Michael Stasko on February 8, 2015 at 8:36 am
    So, I recently shot lots of footage in AVC Intra Using a Panasonic 370 P2
    All of the data is backed up on external HDs and I attempting to edit the MXF file directly in Premiere Pro CS6 (running on Mac Book Pro OS X 10.7.5 OS, 2.3 GHz Intel Core i7 Processor, with 8GB 1600 MHz DDR3 Memory and Graphics are NVIDIA GeForce GT 650M 512 MB)
    * The software seems very clumsy with the files… Takes a long time to import–sometimes does not import at all. Hangs — no way I can work like this…
    I tried getting a converter off the web (supposedly the best out there for converting MXF to MPEG-2, but the footage quality has been compromised…)
    ***Any thoughts suggestions and advice would be greatly appreciated.
    Michael
    Jon Doughtie replied 11 years, 7 months ago 3 Members · 5 Replies
  • Tero Ahlfors
    February 8, 2015 at 9:41 am
    Are you importing the files through the media browser?
  • Michael Stasko
    February 8, 2015 at 3:16 pm
    Nope — I am just going to: File – > Import…
    But now I will try through the media browser… Thanks.
  • Michael Stasko
    February 9, 2015 at 6:28 am
    Problem solved – Happy that was so easy
    Thank you
  • Tero Ahlfors
    February 9, 2015 at 5:22 pm
    If you have formats with weird directory structures (AVCHD, P2 wtc) then you should use the media browser when importing.
  • Jon Doughtie
    February 9, 2015 at 7:42 pm
    Also, since P2 has really started to disappear, folks sometime don’t know, or have forgotten it is important to retain the P2 folder/file structure when transferred.
