Activity Forums Adobe Premiere Pro Premiere Pro CS6 Multicam assistance needed [ASAP]
  • Premiere Pro CS6 Multicam assistance needed [ASAP]
    Posted by Cole Yakimishyn on August 23, 2013 at 6:06 am
    Im currently working on a multicamera video and am using the Multicam function. Here is the gist of the story. I have 4 perspectives all with different audio and i need to preserve that audio. When i make a cut in premiere with multicam, it only uses audio track one… I am trying to make it so that when i cut to a video source, the audio cuts to the sources as well. I have tried enabling all audio before putting the multicam sequence in the timeline but then it just merges all the audio together and i get a huge mess of audio.
    Your help is very much appreciated! Thanks.
    Cole Yakimishyn replied 13 years ago 2 Members · 2 Replies
  • Roel Bus
    August 23, 2013 at 12:30 pm
    Hi Cole,
    So you have already enabled (click visibility icon) on all the audio tracks.
    In the Multicam track, you need to select just the audio track, choose Clip > Multi-camera > enable. Open the Multi-Camera monitor and select in the submenu the “Audio follows video” option.
    That should do it.
  • Cole Yakimishyn
    August 23, 2013 at 7:39 pm
    Thank you so much! Cut all the audio just right!
