Activity Forums Adobe Premiere Pro Premiere Pro CS6 Dynamic Link (GTX 480)
  • Premiere Pro CS6 Dynamic Link (GTX 480)
    Posted by John Connor on July 14, 2012 at 5:31 pm
    Hello. I have very limited knowledge about codecs, formats etc.
    I’m about to trade my HD 6950 2GB for a GTX 480.
    This is a bad trade from gamers perspective.
    I do fair amount of editing with WMV files, AVI files.
    These files are usually converted into WMV or AVI from different format, such as MKV(h.264), or from fraps (AVI).
    I was wondering if the gtx 480 would benefit me. I always use Premiere Pro and After Effects to edit (using dynamic link). I do all the previews and cuts in Premiere Pro, while effects on After Effects.
    I use effects from CC, lots of twitch. 3D camera movements.
    Multiple layers of colour correction (mojo, curves, exposure, tritone).
    Will I see a big difference using the GTX 480 (CUDA)?
    John Connor replied 14 years, 2 months ago 3 Members · 3 Replies
  • Michael Murphy
    July 14, 2012 at 9:03 pm
    The GTX 480 is a great card that will help immensely with CS6.
    I am not familiar with the card that you are replacing – does it support Open CL, do you have ity enabled, etc?
    There is a lot of infotmation on cards here:
    https://www.studio1productions.com/Articles/PremiereCS5.htm
    You can also look at the configuartion of the higher performing machines in this database (for CS5.5) The GTX 480 is a very popular card:
    https://ppbm5.com/DB-PPBM5-2.php
    Good luck!
    Michael
    Best,
    Michael
  • Walter Soyka
    July 15, 2012 at 4:43 pm
    [John Connor] “I do fair amount of editing with WMV files, AVI files. These files are usually converted into WMV or AVI from different format, such as MKV(h.264), or from fraps (AVI).”
    The GPU does not accelerate decoding media.
    [John Connor] “I was wondering if the gtx 480 would benefit me. I always use Premiere Pro and After Effects to edit (using dynamic link). I do all the previews and cuts in Premiere Pro, while effects on After Effects. I use effects from CC, lots of twitch. 3D camera movements. Multiple layers of colour correction (mojo, curves, exposure, tritone). Will I see a big difference using the GTX 480 (CUDA)?”
    AE’s GPU acceleration is limited to the new 3D ray-tracing renderer. Classic 3D rendering and effects such as you have listed will render on the CPU, not the GPU (Mojo may be an exception here, but if it is GPU acclerated, it’s not likely dependent on CUDA).
    Premiere’s effects pipeline IS GPU-accelerated, so if you could do your color correction with Premiere’s effects, you should see a noticeable difference with a CUDA card.
    Check out Todd Kopriva’s blog post CUDA, OpenCL, Mercury Playback Engine, and Adobe Premiere Pro [link] for a full description of what features are hardware-accelerated by the GPU.
    Walter Soyka
  • John Connor
    July 21, 2012 at 4:03 am
    Will the gpu will increase the pre render speed of the footage?
    There are few videos on youtube show how an nvidia gpu can increase the playback(pre view), but no one of them show pre render speed is affected.
    the effects that i use on my footage makes the normal preview (just pressing “space”) impossible.
    Also does the colour correction has to be done strictly on premiere pro? or does it get accelerated even if done in after effects (dynamic link).
    As time passes will there be more effects supported by cuda?
    and The HD 6950 does support opencl.
