Activity Forums Adobe Premiere Pro Premiere Pro CS6 and Encore
  • Premiere Pro CS6 and Encore
    Posted by Victoria Guzik on August 30, 2014 at 12:27 am
    Just edited a wedding video in Premiere Pro cs6 with 8 tracks audio. Tried in two ways using dynamic link to get it into encore. When I go directly from premiere it seems to stop at 50%. When I use encore it freezes at one of the songs. When it does load into encore there is no sound. Once there was about three seconds of sound. This is a new computer system using Windows 7 and was set up by Safe Harbour Computers. Thanks for any help.
    Victoria
    Victoria Guzik replied 12 years ago 2 Members · 2 Replies
  • Ann Bens
    August 30, 2014 at 5:57 pm
    If a song gives trouble make sure its a wav.
    Export from Premiere with mpeg-2dvd (if source is HD its upper field) and import the two files into Encore.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Victoria Guzik
    August 30, 2014 at 7:42 pm
    Thank you so much for getting back to me. I never give up when I have a problem. I keep trying to find a solution. And, I did. I had the wrong player in Premiere Pro. Forget what it was, but it was supposed to be Adobe Desktop Player. Once I selected that I worked fine. Once again, thank you. This forum has helped me a lot.
    Library was missing also. Got the solution for that on line. Seems to be working fine until the next problem. lol
    Victoria
