Activity Forums Adobe Premiere Pro Premiere Pro CS6 and Asus Thunderbolt MOBO
  • Premiere Pro CS6 and Asus Thunderbolt MOBO
    Posted by Brooks Willig on July 10, 2012 at 1:27 am
    Howdy. I was curious to see if anyone out here has built a editing machine on the new Asus P8Z77-V motherboard. I just built one and it seems to be a great machine. However I am experience some issues. I’m not sure if it is that Adobe needs to code some support in for the the LucidLogix MVP software that manages the internal and external graphics cards or there is something I did wrong.
    Here is the specs of my machine
    Apple 27″ Thunderbolt Display
    Matrox MXO2 Mini with Max Thunderbolt
    Asus P8Z77-V Mobo
    Mushkin 32gb of DDR3 SDRAM 1333 4x8GB
    Intel Core i7-3770 Ive Bridge 3.4ghz system OC to 4.2ghz
    EVGA 03G-P3-1588-AR GeForce GTX 580 (Fermi) Classified 3072MB 384-bit GDDR5
    OCZ 120gb SSD
    Video Raid is
    4x 1tb WD Black HDD
    Connected to the on board Marvell sata controller
    Win 7 Ultimate Sp-1
    Right now when I call PPro up and play any video clip I get no video just audio. When I go to control panel and open device manager the video will start playing and then I can edit.
    It seems to be playing a single stream just fine. However when I am doing multi-cam edits, the video will play fine for a few minuts then it will start to hang and lag behind on me. Also I can’t smoothly scrub through the time line like you see on the Adobe videos explaining the mercury playback engine.
    My goals are to use PPro on my thunderbolt display through the thunderbolt port and be able to play back smoothly with out having to go open other stuff to make it work. The Nvidia card is mainly there to support the mercury playback engine.
    Oh right now I am editing footage from Canon XF100s full 50mps 1080i.
    I did a drive speed test on my raid and am getting about 320mb/s read and write speed.
    Brooks Willig
    Owner/ Audio Engineer
    Western Audio Works
    http://www.westernaudioworks.com
    westernaudioworks@gmail.com
    Bobby Batman replied 13 years, 10 months ago 4 Members · 6 Replies
  • Alex Gerulaitis
    July 10, 2012 at 3:02 am
    If I am not mistaken that graphics card is seriously overclocked – primarily for gaming purposes. Possibly a culprit? Is there a way to slow it down a bit?
    If not, can you borrow a different graphics card (that still works for MPE purposes) and try it out?
    Alex Gerulaitis
    Systems Integrator
    DV411 – Los Angeles, CA
  • Gunter Hemeleers
    July 11, 2012 at 7:56 am
    I’m not a big fan of onboard raid controllers, my experience is that they are not suited for video editing, they miss power and sustained speed. Go for a separate raid controller adaptec/atto.
    We had a kickass HP workstation with onboard raid choking all the time, made HP swap out motherboards 2 times, CPU’s 1 time.
    No results at all.
    put in a medium range adaptec raid controller and all the problems dissapeared.
    Hemeleers Gunter
    Mac Pro, Imac 24″, Macbook Pro 15″ all intel
  • Brooks Willig
    July 13, 2012 at 2:43 am
    I’m wondering if I should in install the lucid logix application that’s it supposed to switch between the onboard graphics and the GPU. Will it work to have the integrated graphics render the GUI and have the GTX strictly for the MPE. Will adobe see the GTX if I have the displays on the integrated graphics.
    Brooks Willig
    Western Audio Works
  • Brooks Willig
    July 13, 2012 at 9:26 am
    I got it to work. I disabled the Virtu MVP software and support in BIOS and also finally got the correct Nvidia Driver installed. I found 296.10 works anything later does not.
    Brooks Willig
    Western Audio Works
  • Alex Gerulaitis
    July 13, 2012 at 6:19 pm
    [Brooks Willig] “I got it to work. I disabled the Virtu MVP software and support in BIOS and also finally got the correct Nvidia Driver installed. I found 296.10 works anything later does not.”
    Kudos. Disabled the onboard graphics?
    Alex Gerulaitis
    Systems Integrator
  • Bobby Batman
    November 12, 2012 at 10:37 am
    Hi Brooks,
    Thanks for your informative posts – really useful for a newbie like me. This is the first time I am building a desktop PC so I am not an expert. I intend to use this mainly for video editing in Premiere Pro CS6.
    Configuration:
    Intel DZ77RE-75K
    Intel 3770K
    32 GB RAM
    GTX-680
    Windows 7 Pro – SP1
    My question:
    Were you able to use LucidLogix Virtu to use Intel graphics for decoding/encoding and use GTX and all the power of CUDA for MPE seamlessly (without rebooting, hardware changes, driver changes etc.) ?
    Gautam.
