Activity › Forums › Adobe Premiere Pro › Premiere Pro CS5 – Slow Clunky UI Problem
Posted by Shane Newville on April 24, 2012 at 3:32 pmVideo playback is fine after it’s rendered.
But navigating the timeline and UI is extremely slow and clunky.
Anyone have any ideas why this might be?
I have experienced the CS5 bug where the file keeps growing in size over time for no good reason. Maybe this is the same thing. But if anyone knows of any solutions or work-arounds please tell me.Thanks
System:
Windows 7 Professional 64-bit
Phoenix ROM BIOS PLUS Version 1.10 A13
Intel(R) Xeon(R) CPU W3505 @ 2.53GHz (2 CPUs), ~2.5GHz
12GB RAM
DirectX 11
NVIDIA QUadro NVS 295
and
NVIDIA GeForce GTX 560 TiSoftware and Graphic drivers are up to day.
Shane Newville replied 14 years, 4 months ago 4 Members · 8 Replies -
Vince Becquiot
April 24, 2012 at 5:27 pmHi Shane,
It could be hard to diagnose without looking at the size of your projects or the type of footage you are working with. You haven’t mentioned drives, and that’s often a big reason for slowdowns. A solid 4 drive RAID 5 enclosure is what I would use at a minimum with Premiere nowadays if you are working on a sizable project.
Your CPU may also be on the edge, have you looked at your system performance panel while editing?
RAM and graphics should be just fine for most Premiere tasks.
If could also be worth looking at a small SDD drive to run your OS if you want a snappier interface.
Again, my 2 guesses in order would be drive and CPU.
Vince Becquiot
Kaptis Studios
San Francisco – Bay Area -
Tom Daigon
April 24, 2012 at 6:23 pmThere maybe helpful info in this video. Check it out.
https://tv.adobe.com/watch/learn-premiere-pro-cs5/optimize-a-computer-for-mercury-playback-engine/
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3 -
Shane Newville
April 24, 2012 at 7:07 pmI am surprised that scrolling the timeline alone would be so heavy on processing. I thought video playback would be that biggest CPU hog. And that runs perfectly fine. But when I use middle mouse wheel or click and drag the scroll bar on the timeline it is about a 1-2 second delay. And I see CPU Usage go up to 3% to 40%. And this is without any video playing.
Shane Newville
April 24, 2012 at 7:12 pmI am only running crappy preview quality 720p AVI videos that were playblasted from Poser Pro. But this problem doesn’t seem to be related to video size.
It might just be a good idea to revert back to the lightning fast Premiere Pro 7.0 hehe. Actually that is what my colleague uses and it gets the job done.
Shane Newville
April 24, 2012 at 9:36 pm -
Ann Bens
April 24, 2012 at 11:16 pmDid you install latest update CS5.0.3?
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Shane Newville
May 2, 2012 at 6:58 am[WORK-AROUND]
To anyone else who runs into this problem.The only way I have found to fix Premiere Pro CS5’s ultra slowdown issue is as follows:
1. Create a new Project with the same settings as your current project.
2. Copy & Paste all files and clips from the old project into the new project.This includes all files in the Project window and all clips in the timeline.
Thankfully when you copy (Ctrl + C) it keeps everything in the clipboard even after closing the old project and opening the new.
After I did this the UI was lighting fast again.
This proves updating to the latest version of CS5 does not solve the problem. It’s a pain in the butt to have to do go through this process every so many saves, but at least it restores your project into a fresh new file.Adobe, please fix this bug for CS5 users!
