Activity Forums Adobe Premiere Pro Premiere Pro CS5 Render Manager Equivalent?
  • Premiere Pro CS5 Render Manager Equivalent?
    Posted by Camareo Waller on August 10, 2011 at 3:03 pm
    At my work, I use Final Cut Pro for all editing purposes. FCP has a nifty “Render Manager” feature that allows you to delete all obsolete renders in order to free up precious disk space.
    Since I use PP CS5 at home, I am wondering if there is an equivalent process/Render Manager system in the program? Or would I have do delete obsolete renders manually?
    Research has shown that I can delete old preview files directly in the timeline, but I am not sure if this is running along the same track as FCP’s Render Manager.
    Any help is greatly appreciated.
    James Barton replied 15 years ago 4 Members · 3 Replies
  • Ann Bens
    August 10, 2011 at 5:19 pm
    Have a look at the Project Manager, its under Project.
    https://help.adobe.com/en_US/premierepro/cs/using/WS1c9bc5c2e465a58a91cf0b1038518aef7-7c72a.html
    Adobe Certified Expert Premiere Pro
  • Derek Andonian
    August 10, 2011 at 6:52 pm
    The Sequence menu gives you the option to “Delete Render Files”
    ______________________________________________
    “THAT’S our fail-safe point. Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
  • James Barton
    August 11, 2011 at 6:09 am
    CaMareo–
    The short answer to your question is no–no way to target unused/obsolete render files specifically. Definitely worth a feature request to the Premiere software team–
