Activity Forums Adobe Premiere Pro Premiere Pro CS5 project files bloating
  • Premiere Pro CS5 project files bloating
    Posted by Nat Wilson on May 26, 2010 at 2:50 pm
    Has anyone had the same problem that we’re experiencing? – we have Production Premium CS5 installed on a machine with Win 7 Pro x64. We have three separate edits all of which are experiencing bloating of the .prproj project file. Often this bloating seems to occur when no importing of assets has occured, just changes in the edits. A project which started at 5mb has bloated to 1.5GB and we can no longer save it. Another project has bloated to 200mb and continues to grow in size. We have not brought in any weird assets, although we are using hi-def footage.
    We upgrade from CS3 and never had this problem using Premiere CS3.
    We can’t fix the problem by ‘remove unused footage’ as this doesn’t reduce the project size, although it does remove the unused footage.
    We can’t fix it by importing the project into a new clean project as the problem and huge file size just comes with
    We can’t fix it by using the project manager to collect up the project as it requires to save before collecting and the problem files can’t be saved.
    A couple of points to note – these projects were originally on Premiere CS3 and were upgraded to CS5. The footage is either Sony EX3 or Canon 5D – both HD.
    The machine it’s running on has 8gb of RAM.
    Currently the projects I’m working on are gradually grinding to a hold with no way to make the files usable again.
    Any suggestions are greatfully recieved as I’m at a loss. I’ve reported this to Adobe, and will report back if I get anything useful.
    thanks, Nat
    Nat Wilson replied 12 years, 1 month ago 6 Members · 10 Replies
  • 10 Replies
  • Bob Kiger
    May 26, 2010 at 4:30 pm
    I’m assuming that the projects your working on are not yet finished. Have you rendered your timeline for some reason?
    With the new CS5 performance specs, it seems like the older ideas of rendering regularly to get a reasonable screening of the project is no longer a good work flow choice. If CS5 can play unrendered timelines as they openly stated in video and at NAB, than it might be wise to hold back on rendering until your ready for some kind of release. This is especially true if your storage space for projects is limited.
    This is just my first impression at diagnosing the problem you describe.
    Bob Kiger seminal author of “videography” [OCT1972-AMERICAN CINEMATOGRAPHER]
    http://www.videographyblog.com
  • Nat Wilson
    May 26, 2010 at 4:46 pm
    Hi Bob, thanks for taking the time to reply. Unfortunately, although I’m using CS5, I’m not using a video card that can make use of the realtime rendering afforded by the Premiere Pro CS5. Because it’s HD footage I’m needing to render to view a reasonable copy of the edit, which as you guessed is not completed.
    I have plenty of space of the RAIDed edit drive (1TB free). The problem seems to be specific to the project file. I may have to export and EDL and bring that into a brand new CS5 project in order to rule out it being something to do with the project having been converted from CS3, which someone else has suggested could cause a problem. If I do that though I’ll loose a load of grading and reframing that I’ve done 🙁
  • Jon Barrie
    May 26, 2010 at 11:10 pm
    Instead of EDL try AAF export. Might keep most of the scaling and effects? Have to test first.
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
    http://www.suiteskills.com
  • Nat Wilson
    May 27, 2010 at 7:59 am
    Jon – thanks for the suggestion. I didn’t know that AAFs would do that and will try it. A work around has come in from an Adobe employee whereby you create a new project in CS5 and import the timeline, but not the project, which I’ve tested and which works, however there are other people with this problem now and this includes people who originated their edits in CS5, which probably rules out this being a CS3 – CS5 migration issue and hence means the problem won’t necessarily be fixed by this work around.
    I’d encourage people with this problem to also have a look at the Adobe forum where some other people with the problem have posted, and which has the eye of an Adobe employee at the moment:
    https://forums.adobe.com/message/2845669#2845669
    thanks for your help everyone and if I get a solution, I’ll post it here.
    Nat Wilson, Editor / Animatior
    Adobe CS5 Production Premium running on Win 7 Pro x64 8GB RAM
  • Andrew Crawford
    June 18, 2010 at 10:40 am
    Hi Nat,
    for what it’s worth I have noticed a similar phenomenon in CS4, and now also in CS5. I’m working on an HD project, which for some reason suddenly jumps in file size from 40Mb to 160Mb, with absolutely nothing having been added and in fact afeter several sequences are removed. Earlier iterations have been the same size until bang, it triples in size. Nothing like the magnitude you are seeing, but I dont like mysteries like this!
  • Nat Wilson
    June 18, 2010 at 2:01 pm
    Hi Andrew,
    It sounds like you’re experiencing something very similar to that which I and others have seen. Adobe have looked at my project files and have confirmed that there is a bug in CS5 Premiere. I understand that they are working on a fix at the moment and that an update will be sent out for Premiere shortly, but I don’t have a date. There has been no mention of this problem in CS4 though, but now that they know what the problem is, they should know if it affects CS4 and update that also if needed. The word from Adobe is that the problem relates to renders that are done within the editing environment being saved with the project file. You can find out more info by reading the threat which I’ve linked to previously, over at the Adobe Support Forums. I hope this helps, and good luck solving the problem.
    cheers,
    Nat
  • Nathan Daher
    June 18, 2010 at 7:27 pm
    Hey Nat, and all who are experiencing this problem,
    I too found that my Premiere CS5 project file sizes skyrocketed for no reason, so I did a little googling and found this topic. After reading your response that Adobe provided saying it had to do with the rendered files accidentally being saved within the project, an idea struck me.
    I went to Sequence/Delete Render files, then saved my project as a copy. Lo and behold, it went back down to 6mb! Yes, you’ll lose all your preview files, but they can be easily generated back by some overnight rendering, and in your situation it’s at least a temporary workaround so you can save your project. Hope it works for you as well!
    Nathan
  • Nat Wilson
    June 21, 2010 at 10:01 am
    Hi Nathan,
    thanks for explaining in further detail the work around – thats the best solution right now, until Adobe find a fix.
    I’m told that’ll happen soon, fingers crossed, as otherwise Premiere CS5 is a great release.
    cheers,
    N
  • Kuan hua Wang
    August 1, 2014 at 7:29 am
    Hi, Nathan.
    I was having the same problem this morning. My premiere pro file bloat from 7mb to 60mb, and while I was trying to solve the problem was erasing all the unnecessary files and saved. Boomed, it became 120mb. So I browsed many pages until I found your answer. And the problem was solved. I really appreciate it.
    Exy
  • Nat Wilson
    August 18, 2014 at 3:12 pm
    Hi Exy,
    I’m glad that the answer helped you resolve the problem, thanks for letting me know, and good luck with avoiding the bugs 🙂
    Nat
