Activity › Forums › Adobe Premiere Pro › Premiere Pro CS5 – OpenGL Driver error (Nvidia)
  • Premiere Pro CS5 – OpenGL Driver error (Nvidia)
    Posted by Danie Pretorius on January 12, 2012 at 9:06 pm
    I have been experiencing the following problem constantly while editing this specific project in Adobe Premiere Pro CS5.
    While editing and playing or scrubbing the timeline (even in 1/4 resolution), I get the following error like every 5 minutes which is really annoying:
    NVIDIA OpenGL Driver
    “Your hardware configuratin does not meet minimum specifications needed to run the application. The application must close. {;ease visit nvidia…… Error code: 7″
    This does not happen in other projects on the same PC with same setup. I must add that I don’t use PSD files that often for text overlays but have done it before without any problems – this is the 1st time I am using it on clips which have been green screened.
    This project consists of the following:
    2 green screen clips (1080p from Sony EX3 and Nikon DSLR mov files) edited – presenter giving lecture. I am overlaying some text from Photoshop (psd-files) over these clips (have done it before in other projects with no problems). Both clips have been colour corrected (three-way colour corrector) and I have used 8 point garbage mat to assist with green screen masking.
    What can be wrong? I have installed the latest nVidia Drivers, rolled back to older driver version with no success.
    I have read somewhere that one should set the Power Management Mode in the nVidia Control panel settings to ‘Prefer Maximum performance” from adaptive. This did not help.
    Basic Setup summary:
    Motherboard: Asus P6X58D-E
    i7 CPU (Intel)
    12GB RAM
    Windows 7 Professional 64bit
    Adobe CS5 Production Suite (Premiere is version 5.0.3)
    Graphics Card: nVidia GTX470
    I have been using this setup for more than a year and this is the 1st time I am getting this error. This does not happen in other projects – only this one…any ideas?
    If I switch GPU acceleration off (in Project Settings – to Mercury Playback Software only), the error does not appear. So it is something to do with GPU (OpenGL as error states). This is a workaround while editing but not ideal to work like this!
    Anybody experienced the same?
    Regards
    Danie
    South Africa
    Sony EX3, Canon XL1, Adobe Production Suite CS5, Pretoria, South Africa
    Elliott Abbey replied 13 years, 9 months ago 3 Members · 3 Replies
  • Bob Dix
    January 12, 2012 at 11:17 pm
    Download the latest up grade to CS5.5.2 and see what happens ?
    Freelance Imaging & Video
    AUSTRALIA
  • Danie Pretorius
    January 13, 2012 at 3:49 pm
    Thanks Bob!
  • Elliott Abbey
    December 8, 2012 at 10:05 am
    I had this problem after reinstalling premiere on a system that had been running perfectly for months.
    System: ASUS P5KPL-AM EPU / Intel Core 2 Duo E7500 / NVIDIA GeForce GT 240 / 4GB DDR2
    I tried re-installing a clean; Win 7 64bit, Premiere CS6, + Nvidia drivers again from scratch but same problem.
    I found a simple solution that may help others:
    If you have an integrated graphics motherboard the system allocated memory (mine was set at 8MB) it might be clashing with the Nvidia card’s faster memory and causing a Open GL conflict.
    I opened up the BIOS and set shared integrated memory to 0MB and after the restart everything worked great!
    Hope this helps
    e:-)
