Activity Forums Adobe Premiere Pro Premiere Pro CS5 audio clip won’t move into correct timeline!
  • Premiere Pro CS5 audio clip won’t move into correct timeline!
    Posted by Merlin Merton on August 13, 2013 at 8:27 pm
    URGENT: I’ve been trying to sync the sound files to the video clips on premiere pro cs5, but it’s proving a little difficult because the sound files won’t move into a higher-number timeline. Instead it goes straight into ‘audio 7’. Is there any way of moving it into audio 1? Thanks in advance for help!
    Andrew Drachman replied 13 years ago 2 Members · 1 Reply
  • Andrew Drachman
    August 14, 2013 at 2:49 pm
    You may have the Audio 7 line highlighted. When you click on the area surrounding the track options, it turns a lighter grey (or darker if it is already chosen). That is how you set preferences for which tracks the clips move to when copying and pasting.
    Note: If you have multiple tracks highlighted, the clips will be copied to the lowest numbered track. For example, if you have tracks 1 and 7 highlighted, the clips will be placed on track 1.
