Activity › Forums › Adobe Premiere Pro › Premiere Pro CS4 Problem
  • Premiere Pro CS4 Problem
    Posted by Steven Mcdonald on December 23, 2012 at 4:41 pm
    After a lay off of a few months I attempted to create a movie file (tried at least half a dozen formats) but Premiere Pro gets so far through then stops. It’s a video of about 15 minutes and I have never had this before. Any help would be much appreciated as I am tearing out what little hair I have left.
    Thanking you in anticipation
    Steve
    Ivan Myles replied 13 years, 8 months ago 3 Members · 2 Replies
  • Angelo Lorenzo
    December 23, 2012 at 9:08 pm
    Export as an image sequence, see where it dies then inspect the video clip it dies on for any corruption or other issues.
    If you’re pressed for time then export, see where it dies then pick up a second export one frame after. Combine the two image sequences and deal with the frame skip by duplicating or blending a frame.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Ivan Myles
    January 6, 2013 at 7:11 am
    Premiere Pro tends to struggle when applying effects to highly compressed footage. If there are any MP3 audio files in the timeline, convert these files to uncompressed wav format. If the problem persists, look at the video files.
