Activity › Forums › Adobe Premiere Pro › Premiere Pro CS4 – Object edges cut off when drop shadow is applied
  • Premiere Pro CS4 – Object edges cut off when drop shadow is applied
    Posted by Dane Cooke on October 1, 2009 at 3:51 pm
    I have a gif logo with transparency that I have applied drop shadow and motion to. It looks fine during preview, but when I export the sequence, the edges of the logo are cut off.
    Any ideas?
    Dane Cooke replied 17 years ago 2 Members · 2 Replies
  • Mark Hollis
    October 1, 2009 at 4:43 pm
    Yes.
    Is your logo bigger than the raster? If you resize in Premiere, the application may be applying the original limitations of the raster to the image.
    Try doing a resize in Photoshop or Illustrator. Better yet, do the drop shadow in those applications so you don’t have to in Premiere. Remember, you can add transparency to alpha.
    What if there were no hypothetical questions?
  • Dane Cooke
    October 1, 2009 at 6:09 pm
    Thank you for the quick reply. Got it fixed.
