Activity Forums Adobe Premiere Pro Premiere Pro CS4 CONSTANTLY crashing
  • Premiere Pro CS4 CONSTANTLY crashing
    Posted by Chris Varner on July 23, 2009 at 6:07 pm
    I’m losing my mind. This program is constantly crashing while editing during a host of functions: rendering, trimming, titling – you name it. I’m under the gun here and I’m going crazy. Please help me make this system more stable:
    Premiere Pro CS4
    Windows XP Pro V.2002
    SP3
    Dell Precision PWS 690 Quad Core
    Intel Xeon CPU
    E5320 @ 1.86Ghz
    1.86 Ghz, 3.00 GB Ram
    Thanks in advance. Dyin ovah heah.
    Vince Becquiot replied 17 years, 1 month ago 3 Members · 5 Replies
  • Peter Berthet
    July 24, 2009 at 12:35 am
    are you running the latest CS4 updates ?
    how large is your project?
    what sort of media are you using ? SD/HD 1080i ? HDV ?
    more system specs please!
    ~Peter Berthet
    Sydney, Australia
  • Chris Varner
    July 27, 2009 at 6:16 pm
    HDV 1080i NTSC project
    1/2 hour TV show. Close to 700 clips.
    Dell Precision 690 Tower / Quad core. 4g Ram / @ 1.86Ghz
    I’ve tweaked everything I know how to tweak and the problem seems to be isolated to rendering at this point. I have my RAM maxed out. I defrag frequently.
    I have all of my footage, etc. on one internal drive. I have all of my previews going to another internal drive. Nothing going to the C drive and nothing going to a fourth internal drive.
    Is this a scratch disc issue? How should they be set up?
    What else could be causing this? It’s killing me.
  • Vince Becquiot
    July 27, 2009 at 6:27 pm
    Did you check the performance tab in Windows to see if you are exceeding your physical RAM ? It’s quite possible in you are working in 64 bits.
    Other causes could be background programs. No antivirus, spyware remover, etc.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Chris Varner
    July 27, 2009 at 8:28 pm
    If I’m running 32 bit XP I can’t be working at 64 can I? No programs running in the background. Just crashed (hard) again. Third time this afternoon. Each time was during a render.
  • Vince Becquiot
    July 27, 2009 at 9:06 pm
    Do watch that memory, it does go up at its highest during render and playback, I’d say there’s a good chance that’s the issue. Basically as the projects get larger, you’ll need faster drives (possibly RAID) and more memory.
    Vince Becquiot
    Kaptis Studios
