Activity Forums Adobe Premiere Pro Premiere Pro CS3 will not open
  • Premiere Pro CS3 will not open
    Posted by Vicki Moroughan on December 9, 2007 at 11:52 pm
    I was working on a Premiere Pro CS3 project earlier today, but the sound was not playing after rendering, however, I could hear sound as I scrubbed over the footage. The sound worked fine when opened at a earlier time. I closed the program, but when I tried to reopen it , Premiere Pro would go through to the point of loading effects then crashes. I tried several other projects with the same result. I uninstalled and reinstalled Premiere Pro CS3 from the Production Suite, but still get the same results. I downloaded the CS3.1.1 update a few days ago, but have used the Premiere Pro CS3 since that time. Thank you very much in advance for any suggestions.Vicki Moroughan
    Vicki Moroughan
    Vince Becquiot replied 18 years, 8 months ago 2 Members · 1 Reply
  • Vince Becquiot
    December 10, 2007 at 1:47 am
    Try deleting your preferences, then a system restore.
    Vince
