Premiere Pro CS3 Sound Repeat Issue
Okay so here’s the skinny:
So a client needs some HDV footage edited down. I only do SD at home so I had to borrow his Sony HVD-HD1000U to capture to my computer. At first I was having issues with the batch capture itself. So after several tries I ended up doing a live capture of everything I needed. It finally worked. I put a clip on the timeline and was scrubbing through and noticed the audio wasn’t synced. Further investigation showed that the entire captured clip, restarts the audio from the beginning, at exactly the middle of the clip. I opened the Movie Clip in Windows Media Player for playback and it works fine. It’s Premiere CS3 where I have the issues.
I tried using new project files with different settings and it still interpolates the footage exactly the same. Any help would be most appreciated.
