Activity Forums Adobe Premiere Pro premiere pro cs3 realtime monitor playback wont work
  • premiere pro cs3 realtime monitor playback wont work
    Posted by Simon Nadin on January 17, 2010 at 5:47 pm
    hello folks
    i wondered if you could help me with a problem ive got with premiere pro cs3.
    ive been working on a project. all was ok until i decided to reinstall XP from a disk image i made some time ago for various reasons unconnected to premiere. as far as i can tell, there are no problems at all with the computer system except for this one:
    when i open the project now, and scrub throught the timeline, nothing happens in the monitor window. when i press spacebar for a preview i get sound playback but the video just shows the frame where i started preview from. when i stop the preview the video jumps to the frame that it would have been on if it had been playing properly. this worked perfectly before the xp image restore. the video is all uncompressed dv from a cannon mv600i, but the same thing happens with all other formats i have tried so. the same thing happens if i create a new project and use footage that wasnt included in the original project.
    if i double click any clip on the timeline it plays perfectly in the source window. all clips also play perfectly if i play them directly with media player or any other player independently of premiere.
    i also have several files which are reported as being offline (red background “offline” thingy) but i never get the “file offline, where is it” error report where you direct premiere to the file if youve moved it by mistake etc (and anyway, i havent moved anything). the “project / link media” menu item is permenantly greyed out so i cant use that.
    its driving me nuts. has anyone any idea what is wrong or what i can do? ive searched various forums but cant find anything to sort it out.
    it was working ok before the disk image restore. can anyone suggest anything? im trying to make a music video of my friend tony and i cant really carry on until its fixed.
    cheers for any advice you can give me.
    Si.
    Ashwin Kapure replied 16 years, 8 months ago 3 Members · 5 Replies
  • Jon Barrie
    January 17, 2010 at 9:07 pm
    Sounds like a video card driver issue. Try newest driver or roll back to one u new u had before ur rebuild.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Simon Nadin
    January 18, 2010 at 7:48 am
    Ive tried that. Any other suggestions? Cheers.
  • Simon Nadin
    January 18, 2010 at 4:35 pm
    sherlock gave me this report.
    can anyone tell me what to do about it?
  • Jon Barrie
    January 18, 2010 at 8:56 pm
    I had a weird thing with hdv mpeg m2t files from onlocation. The same system I captured on wouldn’t allow the files into ppro. The codec got messed up.
    The solution ended up, uninstalling ppro ame ae flash encore and reinstalling them then letting the update run itself for all the apps to get to most upto date versions.
    Worked fine after that.
    – Jon Barrie
    Jon Barrie
    aJBprods
  • Ashwin Kapure
    January 19, 2010 at 6:37 am
    please tell me can u see the dv output on the television through premiere(if u have output card please plugin the television and check for it or i think u should reinstall the software and delete the files from ur os root”c:(for example)” /programfiles/commonfiles here u can find ur decoders folder(for eg. Mainconcept) delete all the plugin folders from the program files from the adobe premiere pro folder and then reinstall
    or if u have an image of ur OS it will be fast and less complicated there might be a problem while ur os was overwritten some files might have been skipped due the some errors(related to file structureof HDD) while overwriting,
    i had similar problems when the OS is overwritten
